Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Ps3 hdmi cable problem
Having problems trying to get it to work.it has work on another ps3 but i cant get mine to work any suggestions or settings i could change
I have a sony bravia 42 LCD TV and cannot get it to take HD from my Virgin + box. We have put an HDMI cable as suggested which works with the PS3 but not with our box.
Posted on Nov 20, 2008
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
    The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
    Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
    If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
    If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
    Hope this helps!
    Sep 19, 2011 | Toshiba 26HF84 26" TV
    Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
    hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
    regards
    shaun
    Jan 08, 2011 | Sony Playstation 3 (PS3) Console
    The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
    what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
    Mar 01, 2010 | Integra DTR-5.1 Receiver
    Dynex tv works. bought ps3. when hooked up to
    I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
    If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
    If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
    If you have done all that, that is strange if it still doesn't work.
    There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
    Jan 01, 2010 | Televison & Video
    Cannot get my HDMI cable linked from my ps3 2 my hd tv
    Try video settings on the playstation 3. Adjust it to reflect hdmi.
    Feb 22, 2009 | Sony Playstation 3 (PS3) Console
    1080p high def issues
    The HDMI cable I had originally wasn't a good enough quality. I purchased an HDMI v1.3 cable and everything works at 1080p. You don't need to pay loads for a cable, got mine from Play for £9.99.
    Mar 29, 2008 | Televison & Video
    No sound through ps3 hdmi
    hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
    Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
    PS3 not working thru HDMI cable
    Same happened to my ps3 one week from new , took it back the the shop and got a refund.
    Oct 06, 2007 | Sony Playstation 3 (PS3) Console
    Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
    272 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
