Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Power cord r&r
How do take apart a Hoover Windtunnel so that the electrical cord can be replaced?
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: replacing a fraayed and twisted power cord on a Hoover windtunnel upright
It has a 35 foot cord on it, but I think an 16g wire should be ok. It may say on the wire what gauge it is and I think that it is either 17 or 18 guage.
Posted on Feb 05, 2008
Agent Don
  • 310 Answers
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=517499
How to replace power cord on Hoover Windtunnel...
Posted by SaxTeacher on Apr 15, 2008
The cord on my Hoover Windtunnel upright vacuum is damaged from having been run over while vacuuming. I purchased a replacement power cord, agitator brush, belt, and filters from the Hoover web site.
I have installed the new brush, belt, and filters. I'm ready to install the replacement cord, but I can't figure out how to access the interior part of the vacuum! I tried removing many different screws but none of them seemed to give me access to the necessary area. Any help would be appreciated!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
Depending on where the cord comes out, you may want to check the owner’s manual for the exploded view of the cord area. Usually the cord comes out of the handle and there should be handle screws to release the existing cord and when you replace the cord mark the wires so that you will replace the new cord in the same manner. If it comes out of the body of the vacuum there are recessed screws that will let out into the vacuum to replace the cord. You don’t want to exceed the repairs cost to the price of what you paid for it. The decision should be yours, example: if the repairs costs are $200.00 and you paid $279.99 then @ that point you would have to decide if the repair costs are worth or do you want to pay the lower cost of repair and continue on. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 07, 2008
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
Can i fix a chewed apart cor on a vaccum cleaner or do i need to replace cord
fix it!! with it unplugged, strip both ends of the chewed area to bare wire and then splice them back together. Wrap the splice with electrical tape!
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Need to replace cord on hoover u5720
un do all screws on back of vac replace cord screw back together
Feb 11, 2009 | Hoover U5720-900 WindTunnel Upright Vacuum
Replacing power cord
I replace one on my U6439-900. I took the back cover off and had to cut the wires and put new wire nuts on. Then I secured them really well with electricians tape. Might help to even put on a zip tie around the wiring. Hope that helps.
Jul 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
102 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
