Question about Sakar IConcepts Avenger (19352) Joystick
How to connect.
I have an Avenger #59352 joystick that I want to use with my Toshiba A45-S121 laptop to run MS Flight Simulator 2002. The cord has 15 pins(two rows, 8 and 7) but it doesn't match the 15 pin receptical on the back of the laptop (5 by 3). Is it possible to get an adapter to make the connection ? Does it have to plug into that receptical or can it be adapted to a USB port? Any help would be appreciated.
David O
I formatted my toshiba satellite a45-s121 laptop then i downloaded the drivers and insalled them but now it won,t work on wireless it keeps saying a network cable is unplugged could u please tell me what...
have you checked if you have downloaded the correct driver....??because in most cases that happens if you have installed a wrong driver....hope if this works
Apr 25, 2011 | Toshiba Satellite A45-S121 Notebook
I have 64 bit system. is ms flight simulator 2002 compatible with that?
MS Flight Simulator 2002 should be compatible with your 64 bit operating system.
It should, SHOULD, normally install.
If you have troubles running the program, I suggest right clicking on the shortcut and run it in XP SP2 compatibility mode. But, you shouldn't have to do that.
Mar 12, 2011 | Microsoft Flight Simulator 2002 Standard...
Should a toshiba a45 s121 mb post without memory installed?
No. The A45 series (and the near identical A40 series) have no base memory: at least one of the two RAM sockets underneath the keyboard needs to be populated for it to post.
Oct 16, 2010 | Toshiba A45-S121 Notebook
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Need nic card driver to get online-(toshiba satellite a45-s121)
On the web, go to and select your country. Look for support or downloads then choose your computer. You should get to a page that has all the latest downloads for your computer. You may want to download them all as they will be the latest, and install them.
Jun 07, 2009 | Toshiba A45-S121 Notebook
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
Dec 27, 2008 | Saitek Aviator AV8R Joystick
Sakar IConcepts Avenger (19352) Joystick Logo
46 people viewed this question
Top Sakar Video Game Consoles & Games Experts
James Wishart
Are you a Sakar Video Game Console and Game Expert? Answer questions, earn points and help others
