Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Hp printer says carriage jam and there is no jam....prints wavy
Printer 7210 hp says carriage jam...what does that mean
    Genius:
  • 1,124 Answers
I keep getting a carriage jam error message. There doesn't appear to be a jam, but I am unable to clear the message and print anything. Also the display screen reads original loaded. No idea what this...
Check the location of the ink carriage. If a piece of paper gets wadded up under this or something else is obstucting it you will see this error.
The original loaded message comes up when a sheet of paper is in the scanner tray.
Apr 01, 2011 | HP Officejet 7210 All-In-One InkJet...
The printing carriage stalled and I get error message : Clear carriage jam ..
This normally happens if there is something jammingthe head assembly from moving along the carriage rail. Turn off the power to the printer and see if you can move the head assembly by hand. Also check that there are no paper jams anywhere in the paper path and that the belt that moves the head assembly has not broken.
Nov 10, 2009 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
Step 2: Check for a broken carriage chute
The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
Step 3: Turn the product off and on again
Step 4: Clear any paper jam.
Step 5: Make sure that the control panel faceplate is correctly installed
Step 6: Plug the All-in-One directly into a wall outlet
Step 7: Perform a partial reset
Step 8: Print a self-test page
Step 9: Service the product. Now this model is outdated as per HP website.
Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer says carriage jam, but I cannot see what the problem is.
I had a "carriage jam" error message.
My son gently wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, took the drive belt off/put it back on (not easy), and found nothing wrong with it. So, I put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
You might also check the belt to make sure that there is nothing that might cause it to hang-up.
Kevin
Nov 29, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Hi...
Try to move the carriage maually left and right ..still does not work...service the printer.
Regards
debroy
Nov 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp officejet 7210 allin one,carriage jam,tried all hp troubleshooting
Kevin
Nov 24, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
My son wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Aug 13, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
I had a "carriage jam" error message. I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Jul 19, 2008 | HP Officejet 7210 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
172 people viewed this question
Ben Johnson
