Question about Dell E173FP 17" LCD Monitor
Monitor does not turn on
I have 17in apple studio display monitor, was working fine for years now all of the sudden just went blank can not turn it on, seems like there is no power in but computer has power cable are connected, I don't know
  • aarachika Nov 19, 2008
    tv having problem,onn for a while with buzzing sound then off. i isolated the h.o.t section no buzzing sound
    primary supply is normal.connecting a 75watts bulb after isolating the h.o.t
    bulb glow up with full brightness.may i change the h.o.t,may i use another h.o.t from any other tv
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Cause of power goingoff: There is a bad 1000uF, 16V capon the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35Vcap for $2. This will work.
Why did the cap gobad? The cap is too close to a heatsink and over heated.
What does this capdo? This cap sends a signal to an ICwhich keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage isapplied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:These monitors are difficult to open.
The two plastic pieces snap together and must be pried apartwith a flat screw driver.
After removing the stand, you need to insert a flat screwdriver at the bottom of the screen where two slots are located. Then work the screwdriver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuitboard.
Unplug the monitor cords from the driver board and removethe screen.
Unscrew the mounting screws from the power supply board andremove.
You will need to pinch the plastic support in the middle ofthe board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will beon the side of the cap. It will be bulged up on the top. You will see burnmarks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + ofthe cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from theheat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
Chances are 1.broken supply cord
2.check fuse
3. in the power supply section please check the capacitors around primary hot
supply,or physically burned parts.
4. h.o.t transistor may short.
5.horizontal output transformer damage.
Posted on Nov 19, 2008
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Monitor will not power on
the best sway to deal with apple products is to bring it to apple themselves......9 out of 10 times they will fix it for nothing
Jan 11, 2013 | Apple Cinema Display 23" HD Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Need Repair Manual for Apple Cinema Display M8149
here is a manual for the 17 in. apple studio http://www.devicemanuals.com/guide/Display%20and%20Video/Apple/Apple-Apple-Studio-Display-(17-inch-CRT)-User%27s-TVRBek9BPT.html
Jun 30, 2009 | Apple Studio 17" Flat Panel LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Apple studio monitor can not turn on
I think better check with an electronic technician who knows how to repair your monitor. Monitor has it's life span. Maybe that time, parts of your monitor back down.
That's what I can suggest.
Nov 17, 2008 | Computers & Internet
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
106 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
