Question about Linksys Wireless-G WRT54G Router
Have been using router but it is not encrypted. How do I find my user name. June byard 2607 S. Main St. Penticton Bc v2a 5j4 jbyard@shaw.ca
  • gubenuj Nov 17, 2008
    Every time I have a problem, someone wants more money. I will remember and not buy this prduct again.
    Genius:
  • 1,124 Answers
Do this:
WRT54G
Before you begin, please try to configure the WRT54G from a hardwired PC for simplicity. Whenever security is changed you’ll need to change the settings on all wireless units so it’s a good rule of thumb to do security changes from a hardwired PC if possible.
Accessing the Router
1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
2. When "Internet Explorer" opens type the routers IP address into the "Address" bar and hit the [Enter] key (The Wireless routers default IP address is http://192.168.1.1)
3. The "Enter Network Password" window will appear.
4. Skip user name and type in your password (admin is the default password), and click OK
Setup Page Security Options
When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page:
1. SSID
a) Delete linksys from the "SSID" field
b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers, in this example we’re using linksys12345678910.
c) Click Apply then Continue
2. SSID Broadcast
SSID broadcasts allows other 802.11b and 802.11g users to see your Access Points SSID, by disabling this option is similar to closing your binds and not letting people see through. If you have Windows XP computer(s), do this step last.
a) Select Disable on the “SSID Broadcast”.
b) Click Apply then Continue
3. WEP
a) Set “Wireless Security” to Enable.
b) Click the Edit Security Settings button.
c) A window will appear prompting you “Do you want to enable the Security Encryption?” click OK.
d) When the "Security Settings" Window appears, set the “Security Mode” to WEP*. Then set the “WEP Encryption” to the 128 bits 26 hex digits option.
NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard
e) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of just security, use security12345, then click the Generate button.
f) After the key has been generated copy the key into a notepad document and copy that file onto a floppy.
*NOTE: There are other security options, which the WRT54G uses, however, not all wireless adapter currently support security implementations such WPA and 802.1x. Most wireless adapters support either 64-bit WEP or 128-bit WEP, so Linksys recommends using WEP unless you know that all of your wireless adapters support WPA.
**NOTE: The passphrase will not work with non-Linksys products, so you will need to use the 1st key that you copied onto floppy. You will also need the key, not the passphrase for using Linksys products under Windows XP
g) Click Apply then Continue
h) Close the window
Posted on Nov 17, 2008
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
flioqsktle4l2on3s2rwrurpaery4ednch7fnrcft2qykek7dl9puwp12tebm2epxiv1cic0cgjbtccmwjiymzmxbli0zgzkwq5ytgrmzmeowlrkzmtdjf24rlu2laabtaaaaaelftksuqmcc
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
Shaw webmail login
Here is the help location explaining how to login to shaw.ca webmail. Shaw Go Global login help Shaw Support Community
Jan 01, 2014 | Computers & Internet
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    I need to secure my network and lock my router
    Plug a cord from your router to your computer. Open up Internet Explorer. In the address field, type 192.168.1.1 a box will pop up asking for a user name and password. For user name enter admin for password, leave blank. If this doesnt work enter password You are now into your router. Navigate to "Wireless" fro here you can turn on the WEP encryption or any other encryption offered. Once in the router, you may change any settings including the user name and password. Hope this helps.
    Jan 12, 2011 | Linksys Wireless-G WRT54G Router
    Need wep/security key
    log in to the router by typing http://192.168.11.1 into your browser, the default user name is root leave the password blank. The wireless encryption page is available from Home by selecting Wireless Encryption. Here, you can manually select the type of wireless encryption you'd like to use.
    Jan 05, 2011 | Buffalo Technology AirStation G54...
    Locking the connection
    you will need the ip adress of the router and the user name and password enter ip adress in enternet browser it might ask for user name and password Then you would find a seting to protect it by a WEP password.
    Jan 02, 2009 | Linksys WRT160N Wireless Router
    Cant get thelaptop to work and very fustrating
    u need to first configure teh wire less on the router>go to the main computer>and open browse window and and in teh address bar type- 192.168.0.1 hit enter u can see login screen
    user name-- admin lower case or blank
    password-- admin lower case or blank or password
    and u can see the set up scren and select wire less setup in the left side and follow this
    Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
    Nov 18, 2007 | NetGear WGR614 Wireless Router
    Linksys Wireless-G WRT54G Router Logo
    99 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
