Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Philips 55PP3363, No Picture, constant Chirping / Squaking.
The TV was recently moved and would not power on at all. When I opened it up I found 1 fuse socket empty right where the power cord enters the chassis and the other half way dislodged. I re-seated the dislodged fuse and replaced the other fuse with a 250v 4amp slow blow fuse (TV specs show 255watts, 4 amps is probably too much) Now, upon pushing power on, I hear the system power up, and it starts to chirp. No other picture is present. Suggestions? Thank you, TJ
  • Anonymous Dec 08, 2007
    I have a Phillips big screen that turned off normal but then would not turn on. No power. I opened the back and swapped the fuse by power cord with one from center of board. Now power comes on and sound works but have no picture. At times you can see green colors & projector seems to make a shorting sound. Both fuses were T5H250v. How can you tell if one is bad with no clear middle? Where can you find the fuses? So anyone know the problem? Thanks...
    Genius:
  • 1,139 Answers
I will assume that one of your fuses had blown. I would venture to suspect that this set was worked on before. What you are hearing is the startup circuit trying to turn the Horizontal oscillator on which will then turn on the High Voltage system on that provides power to the rest of the television. If this is the case I would consider looking at the HV section to make sure things are ok there. Then I would test the HOT to make sure it was not shorted. If it is shorted then you have to test the HOT related components for defective values. If you are not comfortable doing this contact a TV Repair man and inform him of the situation.
Posted on Sep 03, 2007
Model 37PFL5322D/37 phillips tv has a chirping sound, no picture
Your TV is exhibiting a symptom of power supply trouble but repair is not a casual task.
Dec 20, 2013 | Philips 37PFL5332D 37 in. LCD Television
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips chirping
two STK392-120 convergence modules that usually cause the beeping. So I changed them both again, but I also found two open 7.5 ohm resistors are in the general area of the convergence modules, and I replaced them as well. I also replace 1 swollen capacitor that was probably going to blow in the future but not really a problem yet.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Philips 43PP9202 43" Rear Projection...
Model NO:60PP9202/17F
I have a Phillips Model # 60PP9202/17F, when my wife turns it on it makes a chirping sound but after that there is no sound or picture.
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
