Computer is connected to 2701HG-B by Ethernet cable.
2701HG-B is connected to printer by Ethernet cable.
I cannot print.
If I substitute my old ZONET router for the Gateway 2wire 2701HG-B, I am able to printThanks,
Steve
SOURCE: Home wireless network through my 2wire wireless router/DSL modem.
From what I understand the flash drive is for saving the configuration so you can transfer it to other computers that you may want to put on the network.
SOURCE: Gateway Reboots Constantly
Okay Junior,
I've had a lot of customers have known issues with the 2Wire Modem/Router. The problem is its trying to be a router, while at the same time a modem. That's like trying to use one of those shampoo and conditioner all in ones - its not gonna work!
Your best bet is to ask them for a regular DSL modem, and then buy yourself a (preferably) NETGEAR router.
Please let me know if this helps. Take care and good luck!
SOURCE: connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
SOURCE: HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
SOURCE: 2Wire USB Remote NDIS Ethernet driver
When I restart my computer I get a found new hardware message. Asking to download the driver for the 2Wire USB Remote NDIS Ethernet, or put in the installation disc. Do not have the disc anymore please help me to find the driver I need. I have 1000HW 2Wire modem. It seems that until I make this change, I cannot properly sync my Palm Pilot. Could that be true?
I can't print to my Brother MFC-465cd now. It works through a simple hub, but not through this 2701HG-B.
