Samsung will not retain ch5 (cbs) it will automatical swithch ch
My Samsung PN50A400 will not retain ch5 (cbs) it will automatically switch to ch 2 (abc) randomly. It seems to only be an issue with ch5 (cbs) also I do not have a settop box. I have the set plugged into the cable from the wall. One other thing, if I plug the tv into a OTA antenna, ch 5 will not switch automatically. Any suggestions?
3 Suggested Answers
  • 317 Answers
SOURCE: Powers on and off randomly
one of your tubes are bad...call tech
Posted on Nov 26, 2007
  • 8457 Answers
SOURCE: Wanted to try OTA and ditch cable. Unplugged
U rescan channels when u switch back to cable.
Posted on Jan 03, 2010
How do I cancel my cbs account it is automatically taken out every month
You would need to call them to do that we have no connection with CBS
Aug 19, 2016 | Televison & Video
My samsung window ac ,at the display showing ch ,what does
It is not a problem it is just the reminder to clean the filter of the a/c this error display automatically every after 336 hrs, so just clean the filter and reset the CH display by pressing temp up and down arrow key to reset it
Jun 22, 2011 | Samsung AW1203B Air Conditioner
LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jul 27, 2010 | LG L1004R Air Conditioner
Samsung DMR77LHS Dishwasher has power to dishwasher, ciruit breaker is on. Lights on door will not light up, nothing will work
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Apr 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
I switched my samsung hue from NAM 1 to NAM 2 and my phone turned off automatically.I had my phone set to lock on power up and now i cannot figure out my unlock code.
i switched my samsung hue from NAM 1 to NAM 2 and my phone turned off automatically.I had my phone set to lock on power up and now i cannot figure out my unlock code.
Jul 12, 2008 | Cell Phones
Swithch of speaker
the programming of ur handset may b faultty then pliz follow this  1.Go to menu – settings – Reset settings – Default settings – press Yes.
2. scan ur handset with antivirus.
 3.if u don't get solution after that u just go to lg service centre abd ask the to flash ur handset.
Oct 23, 2007 | LG KG320 Cellular Phone
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
