Question about Akai LCT2721AD 27 in. LCD Television
TV will not come on by using the remote control
When I'm getting ready to turn on my AKAI LCD TV first thing in the morning using my remote control it will not come on. I have to unplug the TV, wait a few seconds, then plug it back. The TV will now come on using the remote control.
  • kdavato Dec 03, 2008
    Thanks for you help.... B-u-t that didn't work either. I called Costco's rep's and they told me to hold the "STAND BY" button as well. I was given other commands to try and nothing worked. In the end, since my 10 month old LCD TV is under warranty I took it to TV repair. Thanks again.
  • don5780 Jan 28, 2009
    the TV can receive signals from the charter cable remote control for signal search commands, the the remote control that came with the TV will not turn the set on. I tried unplugging power to the TV and when plubbing in the set I had the standby button depressed, but the problem still persists. The remote that cam with the TV still does not work
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Posted on Nov 26, 2008
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Jan 23, 2017 | Akai Televison & Video
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
Akai ct-2202 tv turns on but no picture when i connect cable tv wire, cable oprator said me your akai tv tuner problum Please solve my problum Sanjeev Kumar Delhi, India
sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : srikum74@gmail.com pls help. thanks & regard's. V.SRIKUMAR
Aug 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Akai lct2715 directv remote code
I can help you with your Akai LCD TV & DirecTV remote control.
This is a list of all the Akai LCD TV control codes for DIrecTV remote controls:
11675, 11676, 11688, 11689, 11692, 11693, & 11935.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 28, 2010 | Akai LCT2715 27 in. LCD Television
AKAI LCT2070 20" TV UNIVERSAL REMOTE CODES & BRAND/ REPLACEMENT
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 25, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai tv remote control
Go to Tigerdirect.com order Logitech Harmony 520 universal remote it is compatible with your AKAI CFTD2011 same as mine. Phone number is 800-800-8300. I also called logitech that makes this remote and it is compatible..........finally a remote that works.............
Mar 11, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai lct2070 need accesory asap
you can get these on ebay i know the power supplys are as cheap as 34 dollars. But the remote you can look for there to but i havent been successful finding one for mine probley cause i dont know what it looks like cause i bought this tv as a demo so they did not have a remote. Hope this helps.
Sep 20, 2008 | Akai LCT2070 20 in. EDTV-Ready LCD...
I am looking for a akai cftd 2011 remote control
I need a remote for a CFTD 2011 for an Akai Tv/DVR
Sep 18, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai LCT2721AD 27 in. LCD Television Logo
131 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
