Question about Konica Minolta DiMAGE Z5 Digital Camera
3 -4 secs. vibration and unstable viewfinder image at power up
Minolta Dimage Z5 works fine except that on power-up the image in theviewfinder seems to roll or shake and appears as multiple images for 2or 3 seconds until the image locks in. It is the same in bothviewfinders. Then all is well. There is a a certain amount of internalknocking /vibration during this time.(It is over and above the normalsound of the lens mechanism which I know from my Z1) The frequency ofvibration varies from very fast to four or five knocks a second. Itseems to come from the real of the lens or behind the largerviewfinder. Nothing is obviously loose or jamming . Power-offworks ok. Zoom works ok. Focus seems ok. Exposure is accurate.Batteriesare new. I recently purchased camera second hand. I have had severalZ1and other cameras none with anything similar. Local dealer has notcome across the fault before either. Hope you can help. I know Minoltaparts are like hen's teeth, but I would like to have some idea of whatit is.
Fishi
  • 255 Answers
SOURCE: Camera won't turn on
Turn the camera off. Take out the card. Take out the battery. Put in the card. Put in the battery. Turn the camera on.
Posted on Sep 13, 2005
Gryfox
  • 216 Answers
SOURCE: Dimage Z5 lens and screen problems
Minolta has been bought by Sony and they're very tight with parts for repair. Unfortunately, it'll have to be repaired by Sony. Go here for details: http://eservice.sony.com/webrma/web/index.do
Posted on Dec 18, 2006
SOURCE: service manual?
The manual is posted here.
Posted on Jan 10, 2008
SOURCE: Konica Minolta DiMage Z5
Hi, I have the same black area in the corner of my shot, and 'fluttering' on turning the camera on. Have called Jessops and a local independent camera shop. Both have told me that Minolta have been bought by Sony, and as such, there is no support for the Minolta cameras, which is very poor. Also, the price of cameras has come down so much over the last few years, that it is cheaper to buy a replacement than to attempt to have it repaired. A Fuji Finepix S5700 was suggested by my independant shop...does a similar job to the Dimage and costs £99. I was quoted £125 to have the Dimage looked at by Jessops! It's a no-brainer for me, although very annoying as I love my Dimage.
Hope this helps a little.
Posted on Aug 02, 2008
hokuwho
  • 306 Answers
SOURCE: focus/zoom issue with Konica Minolta Dimage Z3 digital camera w/ 12x zoom
This is a symptom commonly listed for DiMAGE cameras listed on EBay for 'parts only'. Dropping the camera I had caused the same problem and carefully 'smacking' the camera once again did solve the problem but that may have been dumb luck. Sorry but it is a service task that may cost more than the camera.
Posted on Oct 15, 2008
I see a black croissant on the picture
Z5 probably fell
Lens servo-alignment-motors might be disconnected...
Needs dismantling and check inside (dunno yet how to do it)
But you probably also experience vibrations at start
Mar 03, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Minolta Dimage 5
I solved the problem with a little smack from the palm of my hand! Thanks
Mar 21, 2009 | Konica Minolta Z5 Digital Camera
My Konica Minolta Dimage z5 won't play back photos
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Jan 03, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Oct 27, 2007 | Konica Minolta DiMAGE 7i Digital Camera
Mode switch
my dimage z5 and see alot of problems on ebay the net ....anyways being a tech for 25 years the cover came right off and u can see the switch is surface mounted. there is supposed to be a plastic lever coming out to manually engage to outer switch but missing ...upon closer inspection i could see alot busted up chards of small plastic ...the insideof the switch was completely ruined for bits where falling out...its just stuck in main veiwfinder. cant find the part itself anywhere on net. heard sony bought out minolta. my only bet is buy a broken camera with different prob. on ebay. Larry
Jan 26, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Dec 18, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta Z5
This sounds like a jammed shutter. There is a very delicate assembly inside your lens which blocks light from the image sensor at the moment you snap the picture in order for it to be able to record what it was seeing at that very moment. Normally after the sensor has finished recording the image the shutter will re-open allowing you to compose another image. If you see the icons and text as you would expect, but do not see any image - this shutter jam is the most likely cause. This assembly is so delicate that even slight impacts, condensation, or contamination from dust or dirt can cause the shutter to not open after it has shut resulting in a black image at all times. The shutter will sometimes clear itself and begin functioning again, but usually it requires disassembly and manual re-setting. Due to the complexity of the lens assembly in this camera (because of the anti-shake features) you will need to send the camera to the manufacturer if you wish to get this problem fixed. David Millier Advance Camera Repair
May 23, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
How many images can the DiMAGE Z5 save in a 16MB SD Memory Card?
Still image Image Size: 2560x1920/2048x1536/1600x1200/640x480 Economy : 18 / 26 / 37 / 142 Standard : 9 / 15 / 22 / 101 Fine : 4 / 7 / 12 / 67 Movie 640x480 Fine: 30 fps: 9 sec. / 15fps: 18 sec. 640x480 Std.: 30 fps: 14 sec. / 15 fps: 28 sec. 320x240 Std.: 30 fps: 29 sec. / 15 fps: 57 sec. *The writing speed of the memory card may prematurely end the recording of a movie clip.
Konica Minolta DiMAGE Z5 Digital Camera Logo
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
