Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Removing door handles
We need to move our Kenmore elite but the handles must come off to get throught the doorway. How do we do that?
  • Anonymous Mar 20, 2014
    i am moving, need to pop the handles off to get through the house door, i have a diagram of the parts,just how to get the handles off
  • Anonymous Mar 30, 2014
    door handle is coming off
    Problem Solver:
  • 4 Answers
You need to use a small allen wrench. There are small holes on the top and botton side of each door handle and underneath on the right and left side of the freezer handle. Just insert the proper size allen wrench in each hole and unscrew the handles.
Posted on Nov 22, 2008
We have a sears elite side by side refrigerator. We need to remove the doors so we can move it through our doorway. How do you remove the door and not damage the ice maker
The door hinges should be screwed onto the main box. There is probably a snap cover over the hinge assembly that you can just pop off with a flat screwdriver to access the screws.
Aug 03, 2017 | Sears Refrigerators
Kenmore Elite 106.54602300 freezer door handle coming off. How to tighten it.
this would require removing the seal and inner liner
its not difficult but do pay attention to all the screws
Sep 12, 2013 | Kenmore 54603 / 54606 Side by Side...
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
My Kenmore HE dryer door handle has cracked. How
Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place. has some excellent exploded view diagrams that you can work from as well.
If you have questions, please let me know. I hope this helps you.
Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
Move the handle to the other side?
it may be easies to remove doors, swap hinges to oposite side of doors and fridge.
For handle you will either have hidden tabs with screws to remove, pry off cover, or inside door panel
Aug 27, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Broken door handle
Hi, there should be two screws holding the handle. I looked up my suppliers and this would need to be ordered. The cost is between 21 and 29 dollars, depending on color.
Part#8559750 Graphite color or P#8559751 Black
If I can assist you further, please let me know. I can order the part.
May 15, 2009 | Kenmore Elite HE4 Electric Dryer
Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
Apr 04, 2009 | Whirlpool ED2FHGX Side by Side...
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite smartheat9 model110.85862400
If i remember correctlysix screws on inside of door then the plastic frame comes off and two screws to take off door handle that should set u straight its the six small screws
Jun 02, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
529 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
