If you are putting in a after market sterio,you need to go to autozone or walmart and get a sterio plug that plugs into your factory plug and the wiring diagram will be with your new plug that you bought,real easy!!
go to benz dealer and they will run radio number on some older models the audio unit must be removed to get the numbers to get code info, or go and get aftermarket unit installed.
If you have already installed the Lexmark X2670 driver on your computer (Windows), try to view the printer's User's Guide by going to the Start menu ? All Programs/Programs ? Lexmark 2600 Series ? User's Guide. If not, you can download the User's Guide for free from the Lexmark website at Lexmark 2600 Series User's Guide. User's Guide gives you some other instructions as well on how to use other features of the printer. Thanks.
1. The display (located by heater controls) 2. The tuner (located under dash, above and to the right of the accelerator pedal 3. The EQ on some models and tape deck on others (located in center of dash)
Radio should work with tuner and display minimum If the tuner is gone you are better off going aftermarket
take vehicle to dealership they need sterio and vehicle they will unlock your radio there they need to make sure its you
there is a program but its 600 dollars for it and you can find code but you have to order it
check to see if the sap feature is on. [ this is to listen to a program in another language. disable the feature either with your remote or on the tv, in the menu section or a sap button.
good luck.
wg
