Question about Frigidaire GLEB27S7A Electric Single Oven
No manual for ge talisman royale self cleaning oven
All the instructions on the inside of the door are not visable -need to start self clean and the symbols are not self expanatory.
please help
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: How do you operate the self cleaning option on a
Before you try to run the self clean feature read this tip...
Mnay problems are cuased by the high heat of the self cleaning...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Posted on Mar 15, 2010
livewire874
  • 618 Answers
SOURCE: I need the manual for
http://www.manualsonline.com/homepage/?src=04102010 Try this site
Posted on Nov 17, 2010
How do I operate my self-cleaning oven..no manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I am looking for self cleaning instructions for a GE oven. MOD. VJ33VWLW-3 SER.ZH273130 VOLTS 120/208 KW 8.6 120/240 11.4 LR 27 TYPE B45 CAMCO INC. Made in...
You should have a selector knob turn it to clean then lock door with lever in the front select hrs on the timer should start up
Sep 18, 2011 | GE Ovens
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
I'm trying to self clean the oven. I am following steps in the manual- however, when I press start to self clean, the door lock light flashes, then beeps and the oven turns off. The manual says the door...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE JTP15 Electric Single Oven
I need the manual for GE TALISMAN AMERICANA SELF CLEAN DOUBLE OVEN #J39AJT12611
Nov 17, 2010 | Ovens
How do you operate the self cleaning option on a GE Talisman Royale Stove that's quite old
Heatman101
Mar 12, 2010 | Frigidaire GLEB27S7A Electric Single Oven
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
Jan 05, 2008 | GE JKS05 Electric Single Oven
Self clean
You should have detailed instructions in your owner's manual. Make sure you are moving the door latch (if equipped) from left to right to lock the door.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire GLEB27S7A Electric Single Oven Logo
996 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
