Radio for Lexus LX470 does not come on - Will not accept CDs.
Why dont u try nero that works
Posted on Nov 17, 2008
2001 Lexus lx470 transmission size
4 Speed Automatic Transmission, 4WD.
part number - A343F
Mar 31, 2016 | 2007 Lexus IS 200
When do you change a timing belt on a 1998 lexus lx470 thanks brian
For most Toyota vehicles, to be safe you should change the timing and accessory belts, associated belt tensioners, thermostat, water pump, coolant, plugs, fluids, and filters every 60,000 miles.
Jan 22, 2010 | 1998 Lexus LX470
1999 Lexus LX470 failed inspection because the check engine light doesn't work. Any suggestions why and how to replace if just a bulb?
it was probably removed because someone wanted to sell the car, I would remove the cluster and put a bulb in
Dec 03, 2009 | 1999 Lexus LX470
I cant find my starter motor on my Lexus lx470 1999
Lexus lx470 1999 Starter
Look at the "rear" of the engine where it joins the transmission. Follow the positive cable from the battery to it. Cog with the 'teeth' you see engages the flywheel to start the motor.
962668c.jpg It looks similar to this.
Jun 01, 2009 | 1999 Lexus LX470
Where to buy hydraulic fluid
if dont find hydraulic fluid,you can also uses automatic transm. fluid (DIII),this not cause any problem
Apr 07, 2009 | 2000 Lexus LX470
Replacing the battery in a 1999 Lexus LX470
There are a few thing's, one thing is to not accidentally touch the positive terminal with the negative battery cable or touch the negative terminal with the positive battery cable when your removing or installing the battery, if one of the cable's do touch the other post it may blow some fuse's, on some vehicles with radio anti theft systems when you remove the battery the radio will lock out, if you don't have the code you'll have to take it to a service dealer to have them reset it, other than that it's pretty much straight forward. good luck.
Apr 02, 2009 | 1999 Lexus LX470
How to remove '0 lx-470 radio
Remove wood console panel using 2 flathead screwdrives but be careful not to crack wood (be patient). Pry on the edges evenly and you'll notice it pop out. Once removed there should be several 10mm screws exposed. Remove them and have a box handy to put the screws and bolts in so you don't lose them. Pull out radio and unplug wire harness. I have an after market DVD monitor and DVD player in my LX470. I like it much better than the stock radio. You should consider after market it's much cheaper than the Nakamichi radio and easier to replace in the future.
Feb 02, 2009 | 2000 Lexus LX470
2005 lexus lx470 ahc system
Caution on what to put in the LX470 automatic height adjustment system. Dealer said unless correct fluid is put in the system the seals may fail. Specifically warned against break fluid. Cost to repair is over $3,000. I bought a can of the fluid at the Lexus dealer for about $26. The can was approx. 1/2 gallon.
Dec 21, 2008 | 2003 Lexus LX 470
57 people viewed this question
 Grubhead
Grubhead
