Question about Olympus Stylus 410 / ? 410 Digital Camera
Olympus Stylus Powers itself off
My Olympus Stylus Verve has been powering itself off when I take a photo. When you push the shutter button, it turns itself off, retracting the lens. This doesn't happen every time. Sometimes, it works okay, and takes the photo. Other times it will not,and just shuts off when you try to take a photo. It also does not retain the time/date settings. It was working fine, and then I re-charged the battery and ever since then this has been happening. It always shows a full batter charge when I turn on the camera though.
  • 114 Answers
The power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Posted on Jan 19, 2007
Won't connect to computer
happens to me too, is it because im using mac? they dont compatible with anything you know..
May 18, 2009 | Olympus Stylus Verve / ?-mini Digital...
Outside shutter cover will not open
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Mar 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Shutter v soft
Are you talking about the sliding door that powers on the camera and covers the lens?
There is a metal plate with two screws on the bottom of the sliding door that holds the door to the camera, try tightening the screws and see if that helps. Or else see if the door is slightly bent out of shape, and try to bend it back if you can.
This is a common problem on the Stylus-300 camera, you can buy a replacement door from eBay -
http://cgi.ebay.com/Olympus-Stylus-300-Camera-Parts-Repair-NEW-LENS-BARRIER_W0QQitemZ250147262921QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 19, 2007 | Olympus Camedia Stylus 300 Digital Camera
Battery
The expected battery life of the Stylus Verve is about 300 frames.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
HyperCrystal LCD technology
This new LCD is designed to deliver a 160° angle of viewing so it can be seen clearly from above, from the side, and from below. Where conventional LCD displays fail to deliver clear, visible pictures under bright conditions, the Stylus Verve HyperCrystal LCD is viewable even in bright sunlight at the beach or on the slopes.
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Battery
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Weatherproof
Date and time
With the camera on, press the OK/MENU button. Use the arrow pad to select [MODE MENU]. Select the [SETUP] tab and press the right arrow. Select 'time icon' and press the right arrow. Select the date format and press the right arrow. Use up or down arrows to set each item and press the right arrow to move to the next item. Press the OK/MENU button when you have finished entering the date and time.
Olympus Stylus 410 / ? 410 Digital Camera Logo
96 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
