Panasonic Workio DP-1820E Copier
Problem for Panasonic Workio DP-1820E Copier
Size of received/sent fax
By fmallen on Nov 17, 2008
Why does a sent or received fax sometimes get reduced in size - often to the point of unreadability. It's a Panasonic DP1820E
Solution #1
posted on Oct 14, 2009
Not Rated)
Guru Guy
Rank: Guru
Rating: 87%, 46 votes
you must have the reduction mode on in the fax section. This allows incoming faxes that are larger than the size paper you have available to be printed. You may have you paper set in a direction or size paper that is not the same as the fax being sent.
Was this helpful?
Yes
No
Popular Solutions for Panasonic Workio DP-1820E
Questions and Unsolved Problems for Panasonic Workio DP-1820E
Do you recommend Panasonic Workio DP-1820E Copier?
Answer
Answer
my mita dc 1260 copier has failed to get into simulation mode
Answer
I accidentally erased my brother printer information and need it reinstalled.. what do I do?
Answer
where can I get a scanner chip for a panasonic workio 1820
Answer
I have a faded vertical section when I print on my Workio DP1810 Copier. I have changed the toner so... (More)
Answer
i have a canon pixma 830 it showing a error code a600 anyone can help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Workio DP-1820E...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
