Question about Frigidaire PLMV169DC Microwave Oven
As soon as you push the start button it trips the breaker
Out of the blue our microwave now trips the fuse panel breaker when you push the start button to try and heat something. The unit is not quite 2 years old and not sure about the warranty yet so thought i would see what i could find out about troubleshooting the problem.
  • Anonymous Nov 21, 2008
    As soon as I push the start button it trips the breaker
  • jcarroll678 Dec 08, 2008
    My baked potato sensor will burn a potato to a crisp in a matter of minutes. The smoke detector goes off and the circuit safety outlet in the room had to be replaced. There is definitely a problem with this model. My microwave was 15 months old. Estimate to repair $ 517.39 not counting the $ 70.00 for a repair order. I have all Frigidare appliances in my kitchen. I hope this was not a mistake.
3 Suggested Answers
  • 9098 Answers
SOURCE: microwave just quit working i thought maybe it was a breaker but it wasn't
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
  • 211 Answers
SOURCE: microwave / Frigidare PLMV
What size breaker is protecting the circuit? Per the National Electrical Code, a microwave and a washing machine should each have their own dedicated circuit (and own breaker) rated at 20 amps. Also, if the breaker is old and has tripped many times due to continuous overloading, it may be weakened and could be tripping at a lower amperage than what it is rated. I would try the following:
1. If possible, test the microwave on another circuit and see if it trips that breaker. If possible, use a 20 amp circuit for the test.
2. If you're comfortable with working in an electrical panel safely, place a clamp on ammeter on the hot wire of the affected circuit in the panel and see how much current is being drawn when the microwave is on.
3. If you would rather stay out of the panel, get an inline ammeter/watt meter and plug the microwave into this. If the rating of the microwave is less than 15 amps (1800 watts), you may be able to use a device called a kill-a-watt at a local hardware store. This will show how much power is actually being used by a given appliance.
Posted on May 28, 2009
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Microwave keeps tripping circuit breaker
Chances are you have a shorted "monitor" interlock switch, or its mount is broken.
See this door switch help file.
You can find links to helpful exploded view diagrams and part ordering help here.
To give you more specific help, we would need the brand name and
full model number of your microwave.
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Aug 30, 2012 | Microwave Ovens
Pushing the start button trips the breaker. All functions seems to work, fan, clock etc but it just started as soon as you push start it trips the breaker. Control panel/board seems fine no burn marks.
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Service manual below, troubleshoot with that.
May 04, 2010 | Panasonic NN-P295SF Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Microwave lost all power when I pressed start
Plug a lamp into the circuit where the Microwave is plugged in. If the lamp comes on then you know there is power supplied to the microwave and the problem is one of an internal nature. If your light does not come on then your breaker at the main power panel could have tripped. On each breaker is a number which is its rating in amps. Your Microwave may require a 20 amp circuit.
May 11, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here:
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here: (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
207 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
