Question about Toshiba Satellite A105 Notebook
Display comes on with stripes of color then turns white
I hear its running but display is not working
The display did come on once or twice but then when computer shut down
it turns back to that striping of colors (running vertical ) and fades out to white
It almost looks like a screen saver pattern.
Model Toshiba Satelite A05 series
laptop
I hooked up to another monitor ,but no images on that monitor
  • 458 Answers
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Posted on Nov 17, 2008
It will not turn on.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
May 10, 2016 | Atwood 6 Cubic Ft RV Refrigerator Black...
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
When I print something out there is nothing on the papper
Did you run a test print? And then check and clean the print nozzles:
Make sure there is paper.
Press the "Maintenance" button once to display an A.
Press Black or Color
Let it run its cycles.
If there is still no print:
Press "Maintenance" button twice to display an H
Print "nozzle check"
Let it run it's cycles.
Still nothing:
Press "Maintenance" button until an M
Still nothing:
Replace BOTH cartridges and repeat the first nozzle check.
If this doesn't work, contact Canon
Jan 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Samsung syncmaster t240 with thin colored stripes on display
Once you have stripes or lines in the screen then the only solution is to get the screen replaced but that would cost just as much or even more then getting a whole new monitor.
Aug 14, 2009 | Samsung SyncMaster T240 Monitor
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
LG flatron L1715S
Hi, have you read the manual? More importantly have you installed the display driver on your machine?
LG L1715S Product Support Manuals Warranty More LG
Jan 28, 2018 | LG Flatron L1715S 17" LCD Monitor
AMILO M1451G display
if you can notice this problem in the BIOS then the problem is with the Display adapter .. if you newly bought your computer i suggest you send it back
Dec 29, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Toshiba Satellite A105 Notebook Logo
403 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
