Question about HP Computers & Internet
Whrring sound? - HP Computers & Internet
  • 40 Answers
Sounds like maybe Hard Drive. Also check to make sure there is not a cd or dvd in the drive that could be causing the noise. Another thing could be one of the cooling fans.
Posted on Nov 17, 2008
I have an xvs 1100 custom 54 plate. Recently having problems starting it up, eventually it does fire but only after holding the ignition down for 10+ secs, it makes a whirring sound as though it...
If it normally fired up straight away, and now when you hold it down and release it only makes a whirring sound. Sounds like your starter clutch has failed.
There are little signs when this happens. Often after a successful start you will hear a small whrring sound, or you will go to start it and it will catch then release to a whirring sound.
Aug 02, 2011 | 2003 Yamaha V Star 1100 Classic
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Virago 535 not starting
Sounds like:
A: The starter clutch is slipping and not letting the starter engage the crankshaft
B. The carbs need to be cleaned. If ti has sat unused for more than 30 days, the pilot jets are clogged up causing it to stall (off choke) and be sluggish on acceleration off idle.
Aug 31, 2009 | 1989 Yamaha XV 535 Virago DX
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
Jun 25, 2009 | Intel D865GBF Motherboard
Fuel problem
When you turn your ignition key to the on position, you should hear the fuel **** make a whrring sound . it means that your fuel pump is good. if not , the fuel **** is bad. Even if you took off the fuel pump and powered it directly. That does not mean it is good evev if it turns a bit. It has to have enough pressure.replace the fuel pump. You should have no problems after that.
Feb 02, 2009 | 1997 Subaru Legacy
Washer sounded like airplace in take off and now won't start.
Check your drain pump. Backing from matts are probably clogging pump. No bottom on that unit, so just tip back to access. Pump has small plastic cooling fan on it. Just carefully twist off to remove, CAUTION look for locking tab on pump before removal.
Nov 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Free sound driver
i need creative sound card driwer
Sep 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Mintek 265D dvd stuck in drive
You need to take the back off the unit and you'll see the DVD . Take the DVD out . You may damage the DVD ( scratch it) but don't disasemble the DVD carriage or you may not get it back together. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Mintek LCD TV Progressive Scan DVD Player
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
Tape won't load
Was having a similar problem but the tape would not even partially load. Spent several hours, over the course of several days trying to figure how to fix this and found the following solution to a similar problem on this site. I tried it as a last resort...it worked! Now I just need to figure out what to tell my wife when she asks me "how" I fixed the camera???? Here is what I did...I allowed the mechanism to close without a tape inserted (the only way it WOULD close), gave it a solid - but gentle - whack on the tape side of the camcorder with the palm of my hand...sort of like burping a baby. I said a little prayer to the saint of hopeless causes (St. Jude Thaddeus)...slid the open/eject button, opened the door, slid a tape in, gently pushed it down (where it says "push") and ...the mechanism closed!!! Not sure if the "fix" will last but we'll see and report back if the problem crops up again.
Dec 05, 2006 | Sony DCR-HC42E Mini DV Digital Camcorder
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
