Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Estate by whirlpool washer machine
The lid switch fell off and came apart, now i NEED TO KNOW HOW TO PUT IT BACK TOGHTER.
  • 370 Answers
It most likely broke and you have to take your front panel loose (panel with the timer) There should be 2 screws in the front or back left and right corners. Loosen those then fold the panel back and your lid switch should be on the left side. It just clips in. If your washer is older it is under the case and then you have to take the case off. Do the same steps as above but pop out the 2 brass case clips behind the panel then lift the case off.
Posted on Nov 17, 2008
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Whirlpool Washing Machines
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
Estate washer lid switch
Simple, dont as this could be very dangerouse. as machine will work. Think saftey as you dont want children, or your own limbs ripped from your body for the sake of saving a small ammount of money.
Mar 09, 2010 | Whirlpool LSR6232J Top Load Washer
Lid Switch
HI, The part# is 3949238. There are two ways to replace this switch. The easiest is to remove the two screws holding the lid switch. Pull the switch out enough that you can clip the wires at the switch. Cut the harness off of the new switch leaving enough wire to put wire nuts on connecting them together.
The other way to change the switch is to remove the cabinet. Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can see the lid switch.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Can't figure out how to get the washer apart to put in the lid switch.
If this is a Whirlpool made machine (which includes Sears Kenmore), there's a video here showing how to get the cabinet off for different models.
Apr 25, 2009 | Washing Machines
Whirlpool top load washer gets stuck on spin and stops
your lid switch is most likely bad.you can che.ck this by taking two screws from face of machine and flip face back.you will see a disconnect plug on machine that goes to your lid switch.unplug machine and unplug disconnect at top of washer under the face,you will need a jumper wire to put in 1st and 3rd hole in your disconnected.plug machine back in and see if it will go into spin.you can also put your finger on lid switch and push in on it and if you dont hear it clicking or if you dont see the finger to push in then it is definately lid switch.
Mar 06, 2009 | Whirlpool Washing Machines
WASHER OFF FULL OF WATER
Have you tightened the screws on the hinges? If they get loose, the lid switch will only get an intermitent contact. There are 2 phillips screws on each side of the lid.
Jul 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
CLOTHES WASHER
ck lid switch on new models left rear under top also might try tightening hinge screws left side may even need to adjust lid hinge left side underneath top push back on lower portion slightly this will help it to engage switch better
Jun 01, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
No spin cycle
Try checking out your lid switch first.. mostly cause
Aug 05, 2006 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
49 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
