Question about Panasonic Lumix DMC-LZ2 Digital Camera
Black Screen Everytime I turn on my camera, it goes to a black screen. I have to literarly hold the lens for it to work. It's happened before, but it's alwas fixed itself. However, this has last for a couple of days now.
Lenses may have dust trapped I found when I wiped it with a dry paint brush it cleared this problem however rembember that a brush will also push dust down futher so when it did this a 2nd time I actually gave it a tap on the bottom of the camera and so far touch wood it works fine. hope this helps
Posted on Jun 13, 2007
Kodak M853 black screen
the Screen LCD is faulty. You must replace and dissasembly your camera, for fix it. you have 2 optione a) do it yourself or b) go to the repair shop for fix it.
God bless you
Jul 21, 2012 | Kodak EasyShare M853 Digital Camera
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Olympus FE 270 Digital camera lens, screen, etc not working
Hi!
Hi!
The focus is stuck. Could be sand, dirt or something in the focus gears - well known problem for these lens. Contact your local Olympus service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
Tom
Jul 03, 2009 | Cameras
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Screen is black for photo taking
Not really a solution, but I think you have the same problem I do. I believe that the shutter is sticking. Mine will work for one shot every 3 or 5 power cycles (turn it off and on again)
Oct 16, 2008 | Olympus FE-210 Digital Camera
Camera dropped and now won't turn on!
just push it back in if that dosnt work i cant help u that happened to mine and that worked
Aug 07, 2008 | Polaroid I533P Digital Camera
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Lens Error on my Photosmart M525
The lens extension mechanism is probably damaged,
or the circuit that drives it.
It could also be caused by poor batteries or bad
battery connection
see my other posts on the same topic.
Martin
Jan 19, 2008 | Olympus Stylus 700 / 700 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
104 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
