Question about Roper RAS8445KQ Top Load Washer
Agitater spins around, water won't drain.
I'm trying to repair a problem for my elderly mother, who asked me to
see if i could fix her washing machine that won't spin and will not drain
tub of water. When i set timer to rinse spin cycle, the agitater spins
and the water won't drain.
The problem i'm having is that i can't locate the model # or serial #???
The ''Roper'' model # RAS8445KQ looks like her machine.
I think it's the timer, but not 100% sure.--- Sometimes everything works
and then the next time it doesn't.
I found all kinds of part #s and i can't find any model #?? Where is it
located? Please help me???
  • hollywood295 Nov 20, 2008
    I appreciate the tech information. I never was able to find a model #. I took a chance on the timer
    switch at a cost of $130.00 and luckily for me, it solved the problem. Now mom is very happy and
    her machine should work well for several more years. I thank you and i won't hesitate to use your
    service in the future.
    Best re: Hollywood 2951
  • Anonymous Jan 09, 2009
    my washer work fine but no rinse and dosent drain the water
  • 367 Answers
The model number is located under the lid.
Posted on Nov 18, 2008
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Final Spin Cycle Amiss
depending on the make and the model, especially if it is a top loader, try replacing the belt. when the belts get older they stretch and slip a little, just enought o cause your problem
Oct 10, 2007 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
150 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
