Question about Nikon N80 with 28-100 lens 35mm Film Camera
Nikon N80 film will not load
Recently film stopped and I had to manually re-wind. Now new filw will not load. Do I need to re-set in some way?
5 Suggested Answers
  • 354 Answers
SOURCE: Nikon EM film winding lever is stuck. Can I repair this myself?
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
Posted on Nov 22, 2008
  • 216 Answers
The F2 has a door knob on the bottom cover. Flip out the handle and rotate it counter clockwise to open.
Posted on Apr 08, 2009
  • 13 Answers
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
Posted on May 25, 2009
  • 571 Answers
SOURCE: Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Posted on Aug 18, 2009
  • 571 Answers
SOURCE: can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
0 characters
1 Points
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Instant Cameras
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Instant Cameras
I thought I loaded the film in a Nikon F100. The Camera showed the film was moving 1-24 I got to 24 the film re-winded I took it to get developed and The film was clear I just need to know how the load...
Since you managed to close the back of the camera and shoot, you've placed the actual canister into the camera correctly.
What happened is there are a series of pegs on the left side of the camera, or sometimes just a red indication line, that the film must be placed onto. If you don't lay the film onto this, the camera won't pull the film out of the canister when you shoot, but it will rewind it back into the canister correctly when it thinks you are out of shots. This will result in a blank roll of film.
Feb 16, 2011 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Recently after putting the film in and taking pics I take it for developement and no pics come out Do you think the film is not advancing properly Maybe I didn't get the new film far enough on the spool to...
Probably.  Most cameras give you a mark to which you pul out the film leader.
If your cam is one of the power load/wind/rewind models then you must pull the leader right up to the mark
If is one of the older ones with an advance lever, then you can watch the rewind crank to see if it revolves when you wind on.  If it does not, then you have not engaged the film in the take-up spool properly.
Feb 21, 2010 | Pentax Instant Cameras
Apr 07, 2009 | Nikon Instant Cameras
My nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Jan 03, 2009 | Nikon N55 35mm Film Camera
Noblex Pro 60/150 film overlapping
Just got mine as well! Awesome! mine also overlapped but it is simply a film loading issue. Make certain the film is loaded with the winding nob in the "S" position when the arrow on the film aligns with the red dot. Wind on to shot 1 and it will click and stop. All shots should then line up.
Another tip - take images 1 and 2 of the same pic at the same exposure of the exact same scene. Assuming the rest of the images are taken with the same lighting situation over the next hour or so your local lab should be able to clip test image 1, then process the remainder of the film ("push" or "pull") to give 5 remaining images exposed spot on!!
Cheers from Ralph!
Aug 06, 2008 | Noblex PRO 150 EII Medium Format Camera
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
My camera is showing an error code. How do I trouble shoot
normally this problem comes when the apparture selector ring is not sat to highest appartutr. i.e. f22 or whatever highest apparture available with the lense. just lock it there .
Nov 11, 2006 | Nikon N80 with 28-100 lens 35mm Film...
Nikon N80 with 28-100 lens 35mm Film Camera Logo
Top Nikon Instant Cameras Experts
Steven Wander
Steven Wander
Are you a Nikon Instant Camera Expert? Answer questions, earn points and help others
