Question about Kenmore 62602 Electric Dryer
MY KENMORE DRYER WILL NOT COME ON, IT CAME ON SUDDENLY AS IF GETTING NO POWER
  • 370 Answers
The problem is your motor fuse. There are two different ones and the part numbers are et401 or et402. Take your dryer apart and the fuse around the air duct area and is white in color. Check with an ohm meater. This is an inexpensive part. Make sure when you get it fixed to clear you exhaust vent from the dryer to your outside vent. This fuse gets blown because of restricted air flow.
Posted on Nov 17, 2008
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Well my Kenmore-heavy duty plus dryer is pretty old but always worked great.Well it suddenly stopped getting power period.The power is still live getting to the dryer but the dryer will not respond.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Dryers
No power in dryer suddenly.
check the door switch and also remove the back and check the main fuse,it is white,if one of these is broke you will not get power
May 06, 2010 | Kenmore 64982 Electric Dryer
I have a Kenmore Elite electric dryer that we purchased in 2002. It suddenly stopped working - no light inside dryer, drum doesn't turn it is like all of a sudden there is no power to the appliance. My...
Sounds like you need to replace your electrical breaker in the main control box of the house that feeds the dryer. You should get 120volt on each leg coming into the dryer. Good Luck, I hope this helps Please rate me, Thanks
Dec 26, 2009 | Kenmore 63942 Dryer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
No heat,,timer not advancing
Check with a multi-meter for power on THE heating element's tags (115/220V). If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Kenmore 62602 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
