Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
...CAMERA NOT RESPONDING AT ALL...
I bought this camera from Sears clearance bin, someone had given it back, and now when I got home and I put the battery on the equipment it does not respond (does not turn on,etc), yet it gets warm as if i was using it... what do u reccommend? could it be a deffective battery?
  • 374 Answers
Call the repairs center at 800-706-2534 and then keep choosing option 1. Lie and tell them that you already talked to tech support and tell them that you are having trouble with your battery not charging and getting hot.
Posted on Jul 08, 2007
My Nikon D60 flash has stopped working despite being in flash mode. Any ideas?
My D60 flash problem was that the flash would pop up, but would not flash. The release lever would keep "clicking"...it did no know that the flash was up. Since I was told that the min cost of sending it to Nikon for repair was $250, I downloaded a repair/service manual for the D60 from http://www.tradebit.com/filedetail.php/9029672-nikon-d60-service-repair-manual ($8.99)
This manual gives a step by step assembly and disassembly of the camera.
I actually lucked up and fixed my problem...
Problem Descripton/Solution (short version):
There was a tiny plastic collar at the flash hinge that got pushed back into the camera. This collar served to close a couple of contacts. I stuck a home made wire/double hook tool into the hinge clearance hole and pulled the collar out and snapped it back into place.
Problem Description/Solution (LONG version)
WARNINGS (based on experience)
1. Yes, the flash will still shock the **** out of you..even with the battery out. You will smell burnt hair/flesh.
2. Be careful of the tiny contact leaf springs. They are hard to bend back into the correct position.
3. The #00 screws are easy to strip out. Apply firm pressure, turn slowly, and make sure screw driver is aligned properly.
4. Proceed at own risk (to camera). Make sure your warranty really has run out. There are many ways to make things worse. You can back out now and buy an external flash.
All I had to take apart however was the top cover of the flash (two tiny screws on underside of the flash #00 philips head). I found that there are two tiny copper or gold "leaf spring" contacts that have to close to send a signal that the flash is up. These are located at the hinge where the flash wiring runs into a clearance hole into the camera (hole is a center of rotation of the flash). There is a small plasitc collar that fits into this clearance hole from inside the flash/camera base and through the flash housing at the pivot point and snaps into place via 2 plastic hooks or tabs (download/see repair manual). This collar serves to secure the flash housing to the base but also has a tiny pin sticking out that catches one of the contact leaf springs and closes the circuit. The problem is that this collar got knocked out of place and pushed back into the camera. I made a home made wire/double hook tool out of 22 gauge wire (see attached picture) and worked it into the clearance hole by pinching the hooks together and working it in. Go in above the flash wires (top of hole) since the wire path goes downward into the camera. With some work and luck I was able to hook the edge of the collar and pull it back out and snap it back in place.
I then put the flash cover back on and everything still seems to work.
My Hook Tool....
Sep 12, 2010 | Nikon D60 Digital Camera
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Dec 22, 2008 | Kodak EasyShare Z710 Digital Camera
Camera DSC-T10 doesn't turn on
Since this is now some twelve years old, it has probably reached the end of its working life.
May 26, 2017 | Sony Cyber-shot DSC-T10 Digital Camera
CAMERA
I TOLD MY FRIEND , ABOUT WRITING TO YOU , AND UNKOWN TO ME HE PHONED THE TV PEOPLE , AND THEY MAINTAIN THAT THERE WAS NO CD IN THE BOX , , BUT ACCORDING TO THE BOOK THAT CAME WITH THE CAMERA IN THE BOX , THERE SHOULD BE A CD SO I DO NOT KNOW WHO TO BELEIVE.
THANK YOU ,
FRANK FORD.
Jun 23, 2008 | Vivitar Cameras
Nikon N65
There is a manual for the F65 available online which is I believe a very similar model. You can download the manual from the link below: http://nikonasia-en.custhelp.com/cgi-bin/nikonasia_en.cfg/php/enduser/std_adp.php?p_faqid=3132&p_created=1102164682&p_sid=DlYIXTJi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NiZwX3Byb2RzPTAmcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWY2NQ**&p_li=&p_topview=1 Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 23, 2007 | Nikon N65 35mm SLR Camera
Battery doesnt charge!
well if it´s new.... just go to a olympus dealer and ask them to exchange it
Apr 02, 2007 | Olympus Stylus 700 / 700 Digital Camera
Logitech quickcam communicate stx
Check the camera settings are not too high 320x480 or similair should be enough. Have you installed Windows Messenger live, the new MSN and tried it with that? If your'e problem persists try this problem page. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=534&p_created=1087233145&p_sid=tDSxcPki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQyMiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aWxsIG5vdCBpbnN0YWxs&p_li=&p_topview=1
Mar 04, 2007 | Logitech QuickCam Communicate STX Personal...
Konica-Minolta Dimage Z2 can't turn on
Well, I also bought the DiMAGE Z2, and my problem was similar: It worked for some time, but then it started freezing sometimes, not responding to any button I pressed. One time, it froze, shut off, and I wasn't able to power it up again. In short, the camera was still under its warranty, so I gave it to their lab and they fixed the problem.
May 19, 2006 | Konica Minolta DiMAGE Z2 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
