Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Cracking on inside of refriderator
UNEXPLAINED CRACKING ON INSIDE OF THE REFRIDERATOR, MIDWAY DOWN ON RIGHT SIDE. THE REFRDERATOR IS ONLY 2 YEARS OLD, IS THERE A REASON FOR THIS AND HOW TO FIX THIS ISSUE
    Champion:
  • 210 Answers
This should be a warrenty problem.
Posted on Nov 26, 2008
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
Tip
Unexplained loss of coolant
whenever you have an unexplained loss of coolant...and you positively know your not leaking from the hoses....your car is warning you of impending doom!
My old 89 Beretta had 280k miles on it when i noticed the low coolant light come on, so i topped it off and problem went away, i had no coolant line leaks and just attributed this to old age..i only had to top it off every two weeks, but after a year or so it started getting worse and it was like every week now, after 295k it started running rough and then it went away after driving it about two miles and then it started overheating badly, so i looked inside the radiator and half the coolant was gone, so i felt the upper radiator hose and it was cold, never got hot! it was a stuck thermostat! it was corroded shut! and then i let the car cool completely (took off the radiator cap) and watched it warm up and my worse nightmare was confirmed, bubbles coming out the top and overflowing...blown head gasket!....so my advice is never ever let your car overheat if you can help it, (everytime you do it stresses the gaskets).. and if it does, turn on the heater full blasts, and pull off to the side off the road and check to make sure your fan is working! ...i fixed the problem somewhat though, with "blue devil" gasket sealer, 500 miles after changing five plugs,and runs great, i just cant get the #2 plug out, because that is where the cracked head or gasket problem is. So whenever your car overheats badly or starts to overheat a lot, change out your plugs, and put some antiseize compound on them or you probably wont be able to get them out later when you need too! The old #2 plug only has 10k on it, so i"ll just leave it in, dont want to risk snapping it off!
Blue devil is a bandaid fix!...the correct way to fix your "low mileage" vehicle is to forkout the grand it will take to changeout the gaskets.
on May 15, 2010 | Chevrolet Beretta Cars & Trucks
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Clunking/thumping with spin cycle, reduces as spin speed increase
It's hard to tell without looking at the washer. But my first response would be that the transmission is wearing out. Inside the plastic cover for the adgitator is a metal drive stem. This assembly has a pulley on the bottom where your motor attaches to; inside the bottom of your washer. It is quite common after many years that these go bad. Have you ever noticed unexplained grease or other stains on your clothes after they came out of the wash?
Apr 22, 2010 | Maytag Washing Machines
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Whirlpool fridge walls cracking inside
IF THE WALLS ARE CRACKING FROM POOR MANUFACTURING THAN YOU SHOULD RAISE HELL!!!How many times are consumers paying the repairs for poor quality ???Unless you have caused the cracks ,I do believe Whirlpool would see this was taken care of the honest way.WHAT WAS ONE OF MAYTAG'S UNIQUE QUALITYS THAT STOOD MILES ABOVE THE REST??????
answer: QUALITY CONTROL
Jun 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Dec 07, 2007 | Refrigerators
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
