Question about Refrigerators
Beko TZG 990 freezer tower unit not freezing just hear a switching in the back of freezer as it attemps to switch on every 15min approx all front lights on inc error state
I have exactly the same issue did you ever fix this ?
Posted on Mar 22, 2010
Hi. Why has my Beko fridge freezer ceased freezing. Fan & light still function.
compressor is running? u can hear it? may have a freon leak? or check the defrost timer or cold control thermostat, some freezers have a freezer thermistor may have gone bad can check all with a multi meter
Mar 10, 2015 | Beko Refrigerators
Freezer motor not restarting after it switches off.
Hello Rostakes;
My name is Peter. I am a retired field service refrigeration technician.
When you unplug your unit, then plug it back in you are giving the motor a surge charge with more volts than necessary to run the motor.
A bad evaporator motor will hum. The clicking sound that you hear is the motor fan blade striking something.
You need to check for 2 possible causes:
1.) The back cover in your freezer, that is in front of the evaporator motor and fan is very thin sheet metal and will easily flex. Inspect to ensure that you are not over packing your freezer and pushing against the back cover.
2.) It is common for the evaporator motor fan blade to have interference from icing. Inspect the back cover in front of the evaporator fan for frost and ice. Your freezer goes through a defrost cycle where the unit shuts approximately every 8-10 hours, the defrost heater turns on for about 20 minutes, the unit restarts. This is where they get the term; "Frost Free". If you have frost or ice on the back wall your defrost heater and Bi-Metl need to be replaced.
Due to the limited size of response by the site I can not walk you through the repair procedure for these parts. If necessary submit this repair procedure request to this web site.
Nov 04, 2014 | Refrigerators
My fridge freezer is less than 2 years old and the freezer is not working could it still be under warrenty?
If your fridge is self defrosting then you probably have a stuck defrost timer motor/switch. I can usually be found on the bottom of the front ourside of the fridge. You can try to advance it with a screw driver until you hear a click and once you do hear that click the fan and the compressor should turn on. Ifthey do then you will need to have the defrost timer replaced. After two years I doubt it is in warrenty. The only things that should be in warrenty is the compressor and all of the related tubing in the hermedically sealed unit..
I have had this problem many times and since I am a retierd HVAC engineer I was able to fix these defrost timers, mainly the actual motors that had dried bushings. You would first have to take the timer apart and get into those bushings and use a small amount of a good light oil like 3 in 1 oli. That usually does the trick.
Hope this helped you. If it did then would you please let me know, I would be courious to know.
Good luck,
Marty
Jun 26, 2014 | Beko Fridge/freezer Thermostat Genuine...
I have a Frigidaire freezer , M# GLFU1767FW4 S# WB70936901. The computer keeps on beeping, even when the door is closed, the temperature is fine. I already changed the computer and the door...
Hi, the door switch might have had liquid poured on it freezing it, or the switch itself is bad.
Unplug your refrigerator from the ac outlet, and 0pen the door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door.
Nov 24, 2010 | Microwave Ovens
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Beko cda653f
I'm not familiar with this brand of refrigerator but sounds as if you have a defrost system failure. most refrigs have a defrost timer that you can maually advance into defrost. if you can loate this on the unit then advance into defrost cycle if the heater comes on youll hear a sizzling noise from the ice melting on the heater. this means you have a bad timer. if the heater does not come on then you have a bad heater or defrost termination switch. I tried to find some service info for this mod but was unable to locate anything. good luck peyton
Jan 21, 2009 | Freezers
Refrigerators Logo
221 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
