Question about Bose Lifestyle 12 System
Bose Lifestyle 12 "no display" fix
My unit is around 10 yrs old and have not had display for many years. I have the unit behind TV sitting on the subwoofer so not having display is no biggie. I've always used the remote with no problem for TV/movies on aux, radio, and cd, but would like to fix if possible. I think my problem is a bit more than just "no display". If I remember correctly I don't think the panel buttons work either... Was that the same case with your unit? Can you be a little more specific on the condenser replacement procedure than "its down in the lower left corner...." Is it soldered in? Can you provide part number? Better description of exact component location. Can you get a replacement somewhere like radio shack?
Thanks
  • TRWDESIGNS Nov 22, 2008
    i HAVE THE SAME PROBLEM...LET ME KNOW IF YOU FIND THE CAP PN.
    THANKS
  • 30 Answers
There is a service available to fix the display at www.AnyoneCanFixIt.com They have fast service and way cheaper than Bose.
Posted on Jan 31, 2010
Bose lifestyle plays for 5min shuts down
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Jan 13, 2013 | Bose Lifestyle 8 series II System
How do I setup and new samsung led with a 12 year old bose lifestyle 25 series II?
... According to their manuals. The TV is new so it should cover that end. Bose.com covers the other.
May 14, 2011 | Bose Lifestyle 25 System
The display stopped working on my Bose Lifestyle 12 Home Theater system.Any Ideas on how to fix this???
i did have encounter the same problem!!!! what i did was have the whole capacitor replace ! I didn't bother to have them check beside its will cost you less than $10 this is how a capacitor will look like http://www.allproducts.com/manufacture97/qiyu/product1.jpg . check the ( + )positive ( - )nagative by marking either one on the PCB board before you proceed! very important! good luck
Dec 04, 2009 | Bose Lifestyle 12 System
I own a Bose Lifestyle 12 system and the display on the console has failed. All else works (ie: buttons and remote.) Is it possible to have it reasonably repaired, DIY or must I live with this as is? Thank...
Its working lifestyle 5, 8, 10, 12 receivers Its Easy fix you need open it up and on lover left corner on bottom first capacitor value 3.3uF needs to be replaced.I did all ready 3 units and its all work now
Oct 28, 2009 | Bose Lifestyle 12 System
Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Apr 01, 2009 | Bose Lifestyle 12 System
Bose Lifestyle 12 version 1
Hi, The dead display is possibly down to a capacitor problem, see fixes already covered by me, it's a 33uF capacitor either on the display board or if a newer unit on the main pcb, these cost less than $1 there is only one just change it.
The no audio may be a simple fix, do you have sound from the head set socket?, if yes then look for one of my other fixes on changing a resistor near the control socket, if no then I need to have a think... If the unit has no sound or display after changing the capacitor it could be a power supply fault. Fix the display first and let me know.
Dave
Jan 29, 2009 | Bose Lifestyle 12 System
Lifestyle 12, NO AUDIO and a DEAD DISPLAY
You are correct. The display unit is separate from the audio issue. I have tired to work on a few of these units over the years.
Bose is so proprietary in thier electronics and repair that the average electronics technician cannot service them.
Your only luck it to send the units in for service. If you are dead set on wanting the bose units then, $250 may be worth the repair charges to you.
If I was you, I would retire the Bose equipment and go to my local electronics store to purchase a different brand unit.
Jan 29, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Lifestyle 12 speaks - new HDTV
mount to wall, brackets available to purcahse on loads of on line sites. and from bose direct cost 5 dolurs to 50 dollars eack depending how fancy you want to be.
would recomment also distancing the left right satellites as you will be amazed how much improvement in sound is gained from a well defined centre channel.
also if you want to be really smart. its really not necessary to see the centre satelliet and it could simply sit of the stand behind the tv. with no problem. plus you could use the tv audio input to make the tv as a centre channel. you would be surprised how well that works. make sure you disable the tvs steroe function or your surround sound will not sound too surround....
finally if you have lifestyle series II make sure you conect the 5.1 input to the bass box to your tv. and get rid of the bose cd player , put it out of sight, and loose the remote. will work even better than it did before !
Jan 02, 2008 | Bose Lifestyle 12 System
Bose lifestyle 12
There is a solution to send your Bose in for the repair at www.AnyoneCanFixIt.com They turn the unit around fast and are lots cheaper than what Bose quoted me.
Nov 28, 2007 | Onkyo TX-SR500 Receiver
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
583 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
