Question about Polaroid TTM-2003 Combo
Says "no disc"
Tv/dvd combo suddenly won't play dvd's. A cleaning disc works fine but any other DVD won't play, just says "no disc" Did all the usual toubleshooting per instruction manual.
  • Anonymous Jun 23, 2008
    I've tried all the DVDs I had and I know that it's a problem with the DVD player? It just keeps saying "no disc"
I've found it works after the set has warmed up. I don't know what the problem is. The other thing is I will just keep ejecting - just hit the eject button over and over - open/close etc and after a while it plays. It's REALLY annoying
Posted on Aug 18, 2008
SOURCE:
My Emerson MO # ld320ems TV/DVD combo will not play DVD
Most likely the laser light is burned out, scrap it.
Jul 15, 2018 | Emerson Televison & Video
My daughter has the Disney 13" tv. It's been working fine then all of a sudden it won't play the DVD anymore. It's stuck on the blue 'Disney' screen. Can you help figure out the problem??
Usually kids tv's in bedrooms collect more dust than downstairs.
The laser probably needs cleaning with a special disc or stripping down and doing properly
Jul 20, 2014 | Disney Princess TV/DVD Combo
My toshiba dvd/vcr combo suddenly wont read dvd disc
Maybe the lasers ok but the disc motor is not spinning the disc.
Apr 28, 2014 | Televison & Video
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Magnavox vcr/dvd combo--dvd's play about 1/3 of the way then quit
sounds like bad pick-up unit (optical eye). these will heat up and reduce the fm envelope signal causing the optical eye to not read disc info. not worth repair. (it may could use cleaning, but usually a dirty eye will effect the movies from the beginning not after warm-up. mch
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd player won't work, says no disk
Greetings,
I do not have good news for either of you. These are notorious for having cheap lasers in them and their original purchase price usually makes a repair cost prohibitive. If you are having an intermittent problem where the disc will freeze - then play - then freeze - then play this is often the first indicator that the laser is failing. One easy way to confirm this is to play a compact disc in the player. CDs are easier for the player to read than DVDs are. If it plays CD and you continue to experience problems with DVDs this usually indicates a laser failing. Remember, when buying a consumer electronic product, the price of a thing usually reflects the quality of that thing.
As for cleaning discs; if a laser has enough residue built up on it to prevent the error correction system from overcoming it, then the microfine brushes on a cleaning disc will probably be ineffective at removing that build up. Cleaning discs are akin to the old VCR cleaning tapes, usually ineffective.
Sorry for the bad news,
Rob
Nov 10, 2008 | Polaroid TTM-2003 Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Polaroid TTM-2003 Combo Logo
423 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
