Question about Desa International Blower Glow Warm Wall Heater
Heater shutting off
Have a two brick heater replaced the thermocouple had to help heat it to get the pilot to burn after about 15 seconds pilots shuts off. While pilot burning turned heater to low after about 15 seconds heater shut off and pilot goes out.
  • 50 Answers
It was suggested I clean the pilot. I bought pipe cleaners and cleaned the pilot and now it works as it should. Thank you for the help.
Posted on Nov 18, 2008
    Problem Solver:
  • 17 Answers
This type of heater is very sensitive to the state of the pilot since it uses a Renni type thermocouple to sense a low oxygen situation. Usually the pilot needs to be cleaned. If that does not restore operation only other thing to do is try replacing the thermocouple.
A low pilot will usually hold for a few minutes so I would expect that you have a bad thermocouple.
Y does my glw-warm heater keep shutting off
Is this an unvented heater? They have oxygen depletion sensors which shut off the heater to prevent burning up all the oxygen in the room. Heaters over 10,000 btu's should not be used in small rooms like bedrooms and bathrooms. Other causes could be a dirty pilot orifice. Turn off the unit (so pilot is off) and use a can of compressed air with attached straw, to blow out any dust from the pilot assembly. (Where the pilot flame comes out). This will allow the pilot to burn a strong blue color and keep the thermocouple heated properly. If it's a thermostatically controlled heater, make sure your thermostat bulb is cleaned off regularly. Dust will insulate the bulb from sensing the room temp and will not operate properly. Hope this helps.
Mar 25, 2015 | Heating & Cooling
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Pilot hard to lite when lites stays on about 15 minutes goes out this is on reliance gas hot water heater 101
The thermocouple has gone bad or in this case is going bad to the point that it is useless.
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to ignite natural gas or propane fuel to the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners. Neat huh?
Feb 04, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
The pilot light on our tankless water heater will not stay on.
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out
Sep 20, 2010 | Bosch Water Heaters
My pro comp heater will light the pilot but will not light the heater. It just sparks attempting to light, after a while it will shut off completely.
Could be your thermocouple. The spark should light the pilot and the pilot lights the main burner but if the thermocouple doesn't pick up the heat from the pilot the igniter will keep trying to light it until it times out and shuts off to prevent gas buildup.
Mar 10, 2010 | Procom MN300EPC Heater
VN18TB PILOT LITE GOES OUT STAY LITE TILL HEATER COMES ON AFTER THE HEAT RUNS AND TURNS OFF THE PILOT LITE SHUTS OFF NATURAL GAS VANGUARD
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Jan 04, 2010 | Heating & Cooling
Pilot light lights but when turnd on it does not get hot and shuts off in 1or2 minuts
This is normally caused by the thermocouple. This is the part the pilot light heats up to let the heater know the gas is on and the pilot light is lit. The heater will shut off if it thinks the pilot light is not lit for safety reasons. You will need to change the thermocouple for it to work again correctly.
Nov 12, 2009 | Dyna-Glo RMC-8001SS Heater
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
May 27, 2009 | Endless Summer Blue Rhino 235000...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Desa International Blower Glow Warm Wall Heater Logo
257 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
