Question about Homelite Mighty Lite Lawn Trimmer
Engine dies when excelerating - more gas
Homelite weedeater. Runs on half choke. Runs of full choke for about 15 seconds. When put in the run position - Runs, but then dies when I go to give it more gas.
  • ah6rr Dec 17, 2008
    Mine is less than 3 months old and has the same problem could it be that not enough fuel is getting to the carb when the choke is opened up? What is the best way to adjust the carb settings.
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
How to start
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
Nov 08, 2013 | Poulan WeedEater Hedge Trimmer 25cc Engine
After ten months without use, I start up the Homelite Mighty Lite 26cc gas model blower/vacuum. It runs on half-choke for about 30 seconds and dies or sometimes a few seconds on run and dies. The vacuum...
Well after you clean it out and get it running make sure you dump some sta-bil into the gas tank next time it is going to sit idle for over 3 months. the gas turns into a shellac which glues up the carburetor.
Oct 30, 2010 | Garden
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Jun 22, 2009 | Poulan Garden
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
Engine run @ half choke but will not run in run position
It's starving for fuel. What is it? Sounds like the jets are plugged in the carb. or possibly water in the gas. Remove carb., disassemble, clean and put back together. You should get a rebuild kit for it first so you have new gaskets, etc. when you reassemble. It's a little more complex than I can put in words for you here.
Also empty and clean fuel tank too and start with fresh, clean fuel.
Mar 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,134 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
