Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
No water or ice now
We have been getting water (slowly, but there) through the water dispenser and hollow ice (but ice was being made). After defrosting and letting the lines thaw (my husband thought that was the problem), now neither the water nor the ice is happening. Can you help me? The water line is still turned on --- and I just replaced the filter. HELP!!
  • galo_o Nov 30, 2008
    A very little water from the water line and small ice cubes. I have checked the water line and filter they are clean.
    Champion:
  • 210 Answers
Could be the triple solenoid water valve.
Posted on Nov 26, 2008
Our GE Profile side by side refrigerator is making hollow ice cubes and the water dispenser comes on by itself sporadically for about 3 seconds a few times a day. Over night it filled a whole glass of...
Hello. Hollow cubes is caused when there is not enough water going into the ice cube molds. That said, since you have too much water going into the water dispenser I would suspect that the valve needs to be cleaned or possibly replaced. Joe
Mar 27, 2010 | GE Profile¿ Arctica® Energy...
Some of my ice cubes are hollow from my ice maker.
Sounds like not enough water is being sent to the icemaker from the water valve. Could be a defective valve or a water pressure problem.
If you have a water dispenser, does it seem to have good water flow?
Oct 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Water dispenser is very low
If it connects to your house plumbing via a saddle valve, replace the saddle valve. Avoid the self piercing type as they poke a very small hole in the house water line and will get plugged easily or the needle inside the valve will break off and drift in and out of the hole in the line.Other possibilities are: Plugged water filter (time to replace) or your water line is hooked up to a reverse osmosis system (RO) and you aren't getting enough flow and pressure through the RO system. Connect straight to house plumbing if that's the case. I would imagine you have hollow egg shell looking ice cubes too...?
Dec 19, 2008 | Refrigerators
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Jun 13, 2007 | Amana ARS2661B Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
109 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
