SOURCE: Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
SOURCE: toshiba estudio 161 copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
SOURCE: i am unable to connect the toshiba estudio 161
Well, u need to use the toshiba viewer driver cd. First, u need to install the usb driver for win xp before proceed to install printing driver. For vista, u need to obtain the latest viewer version 2.
SOURCE: How do I move the
There is a hole in the bottom of the finishing trays on the bottom left hand side (towards the back of the copier.) If you stick a slender object ie. screwdriver and then push towards the back of the machine it will release the tray lock and you will be able to slide the trays freely.
