Keeps wanting to initialize unable to use fax function
My 'BROTHER DCP115c' printer unable to initiate (error 4f). Please can you solve itfor me?
Posted on Apr 28, 2009
I went to a troubleshooting site and followed directions there...worked like a charm!
Posted on Nov 18, 2008
Hi, my brother printer keep showing Machine error 46 unable to clean. Thanks
Disconnect the machine from the power for several minutes, then reconnect it. (The machine can be turned off for approximately 24 hours without losing faxes stored in the memory. If the machine will be off longer than 24 hours, you can transfer faxes to another fax machine or you can save the faxes in your PC.
Found on page 101 of the manual at the link below.
Brother Printer
Hope this solves your issue.
Mar 28, 2011 | Brother MFC-820cw All-In-One InkJet...
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
OR Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
Unable to receive faxes
Make sure its set to fax only by pressing the function button and then recieve mode!Keep pressing recieve mode untill it says fax only and press set/ok!Try cleaning the big grey roller at the back of the machine!Good Luck!
Apr 13, 2010 | Canon FAXPHONE L80 Laser
Trying the set up the fax operation for the bizhub C250. I am unable to send or recieve faxes.
I need to know what you did to set it up.The set up goes like this,
1) install card
2) go into service mode
3) touch system 2===option board status===fax (main)===end
4) touch system 1===marketing area===fax target==US=push end twice
5) touch initialization==fax function and communication==yes=yes
6) turn off and on
push the off hook to see if you get a dial tone. If you don't get one check the phone line
Dec 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax
Get manual from Brother Web.
from my memory Set fax to Manual mode. ie initial set up .... menu 0 .....then arrow to Fax mode?.. Get Manual from brother solution centre download page
Cheers
Dec 20, 2007 | Brother Multi-Function Center MFC-240C...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
1,654 people viewed this question
k24674
jasbo
jasbo
