Question about HP Color LaserJet 3500 Printer
Transfer kit-HP 3500 laserjet
Is it possible to print while waiting for the part? It seems odd (or lame) that the machine isn't programmed to send a part replacement warning before the thing quits.
Thank you for help.
    Novelist:
  • 125 Answers
Hi dbourienne:
Yes it is but you may start having print quality problems ,but as long as the part has been ordered and will be installed soon, it will be ok to print.
pdouglasss
Posted on Jan 10, 2009
How do I check current ink levels in cartridges in my HP Laser Jet 3500
I have an hp 3500 printer myself...simpley print out a supplies status page.
on the control panel go to information than scroll thru that until you see supply status page.. i'm not near my machine now.. but take a little time going thru the menus you'll see supplies status page..
i'm using my hp 3500 as a parts machine..so I don't need it.
would you like to purchase the old fuser/transfer belt toner cartridge for realy cheap...i live in PA if you are close..
Jan 06, 2010 | HP Color LaserJet 3500 Printer
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
Hope this works for you
pdouglasss
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
James
Dec 15, 2008 | HP Color LaserJet 3500 Printer
Hp laserjet 3500 transfer kit
Hit the check botton on the control panel for the printer. Scroll down to "Configure Device" and hit the check button. Scroll down to "Resets" and hit the check button. Scroll to "Reset Supplies" and hit the check button. Scroll to "New Transfer Kit" and hit the check button. Scroll to "yes" and hit the check button.
Hit the return button (next to check button) until back at ready again. Transfer belt count should be reset now.
To make sure, from the info menu, scroll down to "print suply stus page" and hit the check button. Transfer belt should read as 100% now.
DON'T WORRY IF IT TAKES MORE THAN ONCE FOR IT TO TAKE. WE'VE SEEN IT TAKE 2 OR 3 TIMES OF REPEATING THE PROCESS (for no good reason) BEFORE THE MACHINE RESETS THE COUNT.
Aug 25, 2008 | HP Color LaserJet 3500 Printer
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
May 06, 2008 | HP Color LaserJet 3500 Printer
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
HP Color LaserJet 3500 Printer Logo
73 people viewed this question
Ben Johnson
