Question about Canon Office Equipment & Supplies
I have a Canon ink jet printer Pixma iP3000. It tells me that the waste ink absorber is full and needs to be replaced. Can you help me? Sonja Schild LearnSmart Publishing
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
ginko
  • 19396 Answers
SOURCE: Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Posted on Mar 13, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
cene765
  • 787 Answers
SOURCE: Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: Canon pixma 150 waste ink absorber full
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
But some time when you get the chance do clean the waste tank out.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 20, 2010
Waste absorber full. How do we empty?
Resetting The waste ink absorber is almost full message on Canon pixma IP3000.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME 3 times. The indicator should be orange.
6: Press Power to set data.
Hope it helps.
May 17, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Power lamp always red. The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber.
You need to have the absorber replaced at a shop where they can reset the count after changing the absorbers, otherwise ink could overflow and make a mess.
Jul 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
How to replace or clean waste ink absorber in Canon PIXMA iP3000
Cleaning or replacing the ink absorber is not for the faint of heart, it's a messy job,wear rubber gloves and old clothes. After the cleaning you still have to reset the counter so it will let you print again, so don't forget that part.
Here is a link to a web page with the full instructions for both procedures.
http://www.polyphoto.com/tutorials/PrintHeadCleaning/CanonCleaningAndReset.html
Dec 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Waste tank absorber full
hi, i have a canon ip 3000 also and i am receiving the same error msg "waste absorber is full".
i received assistance from my brother, whom is a printer, and he said we have to replace or clean the two pads which clean the ink heads.
i did take the printer cover off and am going to clean the pads.
and this should fix the problem.
email me for any questions.
daveandmana@gmail.com
Jul 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000
This should do the trick!
i320 waste ink counter reset.
1. Turn off the printer.
2. Press and hold the POWER button, turn on the printer.
3. The indicator should be green.
3. Press and release the RESUME button , the indicator should be orange.
4. Press and release the RESUME button again, the indicator should be green.
5. Release both buttons.
6.Connect the printer to PC.
7.Open General Tool software,choose ¡°USB PORT¡±.
8.Choose ¡°SET DESTINATION 1 ¡±,OK!
You can download the software at: http://www.it0577.com/yezmao/i320.exe
Dec 03, 2007 | Canon i80 InkJet Printer
47 people viewed this question
old marine
old marine
