Installed XP on older gateway desktop, gateway monitor FDP 1500 goeas black after windows boot u
Disk not reading and making wierd noises
Posted on Nov 17, 2008
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
When Window Media Center start up, i get post, then XP Splash Screen, the mouse appears with a black screen. I started recovery to recover to factory default, it seemed to work fine for a week or so, then...
You have PC problem nto monitor problem since you can see the mouse.
Try booting in safe mode (hit F8) while booting up then go to system restore and set it back to the date you remember before the problem started.
Did you installed any new software or updates before this problem started?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2010 | Gateway 19" Flat Panel LCD Monitor
Blank screen
Try plugging the laptop into an external monitor to make sure the laptop is booting up properly. If it is unplug the monitor from the laptop; or if you know the laptop boots up fine and you get the windows audio when it boots and the initial starting beeps then forget the monitor. Shine a torch or light source on the screen and if you see a faint picture then the inverter on the screen has developed a fault.
jon
Nov 04, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Gateway Monitor 22" flicks on at start up, then shuts down
Coulld be a MBR problem.Try to debug and check in safe mode.Reinstall Operating System.
Jul 06, 2009 | Gateway GT5468 Desktop PC
Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 15, 2009 | Gateway 7330GZ Notebook
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Monitor won't stay up
was anything else installed like memory
does your screen just go black or actually shut off
try and click f8 continuosly while restarting see if that will get you into safe mode
If not you may need to reinstall recovery again
Jan 16, 2009 | Computers & Internet
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Computer won't boot up...
booting files corrupted try to boot by inserting windows 98 bootable cd or windows xp bootable cd
Dec 03, 2007 | Gateway GT4016 Desktop PC
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
