Question about Bosch Classixx WFL 2066 Front Load Washer
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed properly and there are no socks etc caught in the drain at the front. what can I do to get the machine going Same problem with mine - key symbol appears when I try any type of cycle and keeps beeping.  Cycle won't start.  Tried unplugging but still happening. Any ideas?
  • Anonymous Mar 14, 2014
    the draw open symbol keeps coming up even though the draw is closed
  • Anonymous Mar 15, 2014
    key symbol flashing and washing machine wont do a cycle
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Dec 14, 2008
  • 1 more comment
  • jacx999 Mar 27, 2011
    thank you so much for this post, dont know if you will receive this message but u saved me a lot of money and heartache tonight.
  • laned170
    laned170 Feb 01, 2013
    Thank you! This has been driving me potty :-)
  • sueangelidis
    sueangelidis Apr 06, 2013
    Wow,thank you so much,,can't believe how much stress HAS BEEN LIFTED!! LOVE YA
This means the child lock is on. You have to put the machine on and when the little key appears you hold the start button for 5 seconds, this is also how you put the child lock on again if you need too.
Posted on Jun 26, 2009
Machine wont spin or drain and I get a symbol that says: E 18?
Posted on Dec 02, 2009
No drain symbol appearing cleaned and drained will still not operate
Posted on Jun 30, 2009
Error key f:17 keeps appearing a few minutes after the machine starts
Posted on Sep 18, 2011
2 Suggested Answers
SOURCE: Classixx 6 1200 bosch washer...I've
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Posted on Sep 26, 2008
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine has stopped and a symbol of a key is flashing. Door will not open and no program will work
The key and flashing = child lock.
To get rid of this - turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Unable to use washer due to key logo 'flashing'. Have checked the plug at bottom right of machine no blockage there.
Please try this
the key and flashing = child lock.
close washing machine door, turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Than You
Sep 08, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Key symbol flashing on a Bosch Classixx 1400 washing machine
child lock is active usually pressing start button for 5 secs or more cancels it
Dec 07, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx will not start
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
Mar 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
Jul 31, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
7,425 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
