Panasonic PT-53WX52F I noticed that I had a blue, red and green figures and that the screen was stretched (words was cut off at the bottom and side of the screen) so I tried to adjust the convergence and would not line up to the instruction I followed in the manual. So I was told that it was the convergence IC's so I replaced both (carefully) now it will act like it is powering on then turns itself off and the power led flashes 3 times and I noticed that a resistor located in the 18v section on the board glows red hot before the tv shuts down. what coul dbe my problem and how can I fix it.
  • 1694 Answers
SOURCE: Replaced IC chips and fried something
1)WHICH chips?? 2)Which resistors? (locations) 3)It is worth it. 4)Possible,but usually not needed.
Posted on Sep 29, 2007
SOURCE: TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Posted on Feb 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: Convergence Resistors
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jul 09, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
Sep 15, 2011 | Panasonic PT-56WX53 53" Rear Projection...
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I got a Panasonic PT-53wx52f from a friend for free, but I'm wondering if it's even worth fixing to work properly. The picture is warped, most notably at the bottom of the screen there is a "bubble". After...
You can get to the convergence menu using either the front panel buttons or the remote, but once you get there see if you can adjust either red or blue in any direction. If you can't adjust both colors in all directions you will need to replace the convergence chips and possibly a few low value resistors. If you need more details simply reply.
Dec 16, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
I have a Panasonic LCD projector ( PT-AE700U) - I have had it for 4 years. Recently, I noticed it was projecting "blue" pixels on the bottom right hand side (small size maybe 3 x 8 inches) . Over the past...
your color calibration may be off. see if you can set the red green and blue settings all to "0" and see if that works. may want to refer to your manual and see how you can do that and also see if there is a auto calibration
Jan 23, 2009 | Panasonic PT-AE700U Multimedia Projector
Panisonic projection tv pt-53wx52f
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Oct 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Problems with a Panasonic PT-51DX80
Your convergence ICs are bad. You need 2 of them they cost about 10.00 each. If you can solder you can do the repair in about an hour. hey are located on a real huge aluminum heat sink and they will have a number that starts with STK such as STK392-110. Let me know if you need ay additional info.
Jan 23, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
