Question about Xerox 3001 Copier
Paper feed When inserting the document....no problem When inserting the media it does not stop as it should thus there is a 8 inch blank margin at the top.
  • 67 Answers
One of two things. Either the drive clutch is stuck in the engaged mode, or more likely the motion switch is stuck or broken. To test if stuck, feed 8 sheets of paper in when asked, if it keeps going past the 6 inches, push stop and call for repair.
Posted on Jan 01, 2009
    Scholar:
  • 53 Answers
If the doc. feeder is using photoelectric sensor it may be looking straight through it, you can get media with a white band on the front edge to overcome this problem
Posted on Nov 19, 2008
How can I adjust margins when printing from my computer?
I never heard of any printer that might adjust margins like that... but if we're talking of hardly 1/8" difference, are you sure the feed guides are set to a firm running fit, please?
Are you sure the printer drivers are the latest version for your OS?
Has this happened from new, or did something change, please?
Best,
Robbie
Apr 16, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
I am printing on 8 1/2 by 14 paper landscape. The document is not covering the entire paper.
Do you want the document to fill the page from corner to corner? You won't be able to do that due to the margin settings. The printer needs to be able to pull the page through the machine without touching the ink, so it can't print on every available inch of the page. You can minimize the margins as much as your printer will allow under the Page Settings menu, but it will always shrink the document to fit within the margins on the page.
Hope this helps!
Aug 25, 2011 | Epson Stylus 1400 InkJet Photo Printer
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Xerox 3001 Copier Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
