FixYa.com
Tags:
Jenn-Air JCD2389G Side by Side Refrigerator
Jennair JCD2389G side by side (by 3 users)
posted by jgraf on Dec 04, 2006
I replaced the water filter and immediatelt there was a loud buzzing noise, I unplugged the unit, plugged it in again and it was fine overnight now buzzing has begun again???Help!
Comment by jgraf, posted on Dec 05, 2006
The buzzing seems to be coming from above the filter.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jan 05, 2008
LOUD HUMMING AND EVERYTHING DEFROSTS. PLEASE ADVISE
Comment by usarrmy, posted on Dec 09, 2007
similar problem with dacor ef488dcbss, similiar in regards to buzzing sound coming from above freezer
Best Solution
posted on Dec 04, 2006
Thanks for Trying (70)
HVACRH20
Rank:Wiz Wiz
Rating: 85%, 1173 votes
Can you tell where in the unit the buzzing is coming from (top bottom inside outside, etc)? Need a little more information to help.
Comment by HVACRH20, posted on Dec 27, 2006
Wow... there's not really anything up near there that should buzz. Here's a diagram so you can see what's all up there. Does pressing up on the area change the buzzing sound? I'm trying to see what could possibly do that kind of sound there. I guess the filter itself could be defective causing some sort of resononance. Does the sound go away if you put the old filter back in?
http://www.partselect.com/Schematics/May...
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE GSH25JFR Side by Side Refrigerator GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator GE (PSS26MSRSS) Side by Side Refrigerator GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator GE Profile? GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... GE (GTS16BBS) Top Freezer Refrigerator Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Can you Help with these Refrigerators problems?
freezer side leaking!
Our freezer is leaking and... Answer This...
the beverage chiller door flies...
It appears that there is a... Answer This...
JCD2389GT
water on floor under unit Answer This...
shelf
the refridgerator has rotating... Answer This...
ice maker does not despence ice
Jenn air model #jrsd226 there... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
