Question about JVC Televison & Video
How do you change the lamp on a jvc model hd56g787 tv I tried to take off the front but dosent seem to come off is there a trick Lestv 419 townline rd sandusky mi
  • lestv Nov 17, 2008
    is this part you are talk about by the fan assy could you send a pix of where the part is from the back is this part in the middle of the set I took a metal plate off but was not able to go any futher
    do I have to lay the set on its face to remove the lamp from the lite box
    Sergeant:
    Champion:
  • 435 Answers
Hi, its given here. http://guides.fixyourdlp.com/jvc/TS-CL110UAA.php
hope it helps.
Posted on Nov 17, 2008
  • 4,472 Answers
Http://www.nodevice.com/user_manual/jvc/rear_projection_television/hd-56g787.html
Download the user manual for your tv at that link. Once you download the manual refer to p.75 for the specific instructions on lamp replacement. If you need any further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • JVC Master
  • 19,396 Answers
Open the back panel of the tv and gain access to the lamp.
Unscrew the bolt that lock the lamp and unplug the lamp from the SMPS Lamp power supply base.
  • Ginko
    Ginko Nov 17, 2008
    You start unplugging the TV
    You just need to open the lamp door, undo the bolt on th elamp , remove carefully the lamp and fit a new one.
    Follow the procedure below from manual:
    1 Turn off the TV
    2 Unplug power
    3 Remove the lamp cover located below the left side of the TV, there should be a screw holding the cover. See picture:
    4 Follow instructions below to remove the lamp:
    6. You just reinstall the lamp cover.
    7. Perform the following timer reset procedure after installing the lamp:
  • 734 Answers
Please follow the link for step by step replacement of lemp
http://fixyourdlp.com/blog/2007/04/06/how-do-i-reset-my-lamp-timer-counter-after-replacing-my-lamp/
  • futureloginn
    futureloginn Nov 17, 2008
    follow other link its a pdf service manual to change the lamp--
    http://resources.jvc.com/Resources/00/00...
    Genius:
  • 1,030 Answers
If i am not mistaken the lamp on this model can be acessed through the side of tv with a thumbscrew
  • 1 more comment
  • Willie Howell Nov 17, 2008
    door that can be remove easly... then long screwdriver to take out lamp
    Form the user manual. The lamp is located behind the lamp cover below the left side of television. takes a philips screwdriver
    the lamp can be acessed with the television standing up
Jvc rear projection tv HD56G787
There is a fault with its main digital board. Check it.
Jun 21, 2013 | Televison & Video
My jvc hd56g787 went off and now will not come back on, the blue and red light just keep flashing. We had a warning that the tube needed to be replaced for about a week before this. How do I know if it is...
Tv have none of any kind of forces to causes like an objects or person hitting it to the tv LCD screen panel wright?Yes,than tv is good no problems there as tube wise.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 31, 2011 | JVC HD-56G787 Television
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
We lost code for my mothers JVC TV model HD56G787. It is locked, and she died.
As far as I know, there is no code for TV. If you mean V-Chip code, just replace the asterik signs with zeroes. Or enter 0000
Jan 15, 2010 | JVC HD-56G787 Television
Change lamp
Did you reset the lamp timer?
Nov 25, 2009 | JVC TS-CL110UAA Projector Lamp
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
JVC 56" Rear Projection - red tint.
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 19, 2009 | Televison & Video
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
Lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
