Question about Neff 18 in. S5943 Slim-Line Built-in Dishwasher
The detergent dispenser sliding door will not stay closed
When putting in the detergent tablet into the dispenser, the sliding door will not stay shut. Is there an easy way to fix the little sliding door?
  • 69 Answers
It is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Posted on Jan 08, 2009
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
I have a bosch dishwasher model number SGS0902GB/05. I use tablets instead of detergent. I put the tablet in the Dispenser and close the lid, noproblem. I then set the programme and shut the door, I...
Hello Andrew,
I'm more than happy to give step-by-step instructions for replacing the detergent dispenser, however it's not cheap (about £50) and it probably doesn't need to be replaced. Some of the smaller components for the dispenser are available separately, so it would be better to work out what's wrong with it, before replacing any parts - or the entire unit.
The dispenser may be receiving an erroneous signal from the controller to open when the dishwasher is in delay start mode. To check this, switch the power off, insert a tablet in the dispenser, and slide the door closed. Make sure it clicks shut fully (push on the arrow on the door)and then wait for a few minutes to see whether it opens.
If the tablet will stay in the dispenser with the power off, there is nothing wrong with the dispenser. If it opens with the power off, you may just need a new dispenser door or a spring. Please try this simple test, then get back to me for further assistance.
Regards,
BElectric
Apr 12, 2011 | Bosch Dishwashers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Triton XL detergent dispenser won't stay closed
Well this is not a solution by any means but I would just put the tablet or powder directly into the machine-just "chuck it in". It will work just the same. The dispenser itself isnt truly necessary.
Jun 21, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
The cover of detergent dispenser does not open..
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Mar 20, 2008 | Kenmore 24 in. 16534 Built-in Dishwasher
Neff 18 in. S5943 Slim-Line Built-in Dishwasher Logo
595 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
