Faulty lcd monitor
The monitor turns off and on every couple of seconds even when not connected to the computer.When it is connected it shows the windows screen but can,t do much because of it flashing off and on.I have tried a different data cable and power cable but fault still persists
  • mtgazer Jan 24, 2009
    I have a Dell monitor at home which keeps switching off on its own, every now & then. I use an Acer monitor at work and it works fine.
  • Waynet2 Jan 25, 2009
    If your Sceptre X5G is doing the same thing mine is, power goes ON then OFF, and ON, and OFF, every second or two continuously, then Fix4U was *INCORRECT* and it is not a backlight inverter problem. I have the same thing happen to mine and the power is going on and off, not the backlight. I have a couple of other LCD's from another mfg that do have bad inverters, so I know how that behaves as well.
    I am looking for help and I believe the problem may be in the latch or sleep circuits in the monitor's power circuit. More likely the latch circuit since the power light doesn't go amber, but turns completely off. Interestingly though, I can press the power switch and it will turn off and stay off. Once I press the power switch again, it will do the ON/OFF/ON/OFF routine until I turn it off again.
    Champion:
  • 293 Answers
Hi..there,
Don't bother, your lucks just run out.... you've got a busted backlight inverter.
Posted on Nov 21, 2008
Monitors turn on only a couple of seconds
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 23, 2011 | HP f2105 21" LCD Monitor
My monitor is a dell 2000 flat screen 20.1" turns
This is a backlight problem. The picture is there but there is no light from behind the LCD screen. It could be due to faulty capacitors, which are easy to replace. It could be a faulty Inverter transformer, which is harder to fix but he backlight controller board can usually be replaced at a reasonable price. If you have soldering experience you may be able to replace the faulty capacitors - look for capacitors with bulging tops.
Repalcing the inverter board in a job for someone with electronics experience. You can buy a universal inverter board for about £15 to £20 from e-bay.
20 inch monitors can be bought for about £100 to £150 so you need to decide whether it is economical to repair.
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
My monitor is a dell 2000 flat screen 20.1" turns on but after a couple of seconds it goes black and if i turn it off then back on it shows for a few more seconds before it goes black again the power...
don
Feb 18, 2011 | Computers & Internet
Moniter not lighting
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 10, 2010 | AOC LM 520A 15" LCD Monitor
When I switch my 22'' lcd monitor on it displays a message '' disconnected '', I have just bought it secondhand.
The message "disconnected" shows that the LCD not receiving signals from the input source.
Verify that the source is working properly.
If you are using this LCD as a PC monitor, connect it to the PC's VGA out via a VGA cable. Make sure that your PC's display output is working (are you able to use another monitor?).
Also try using another VGA cable to check if your old one is faulty.
After making appropriate connections, turn your LCD off and then back on after 10 seconds.
If your problem is still unsolved, it may be a sign of a faulty component inside the LCD but the chances are rare.
Nov 03, 2009 | Computers & Internet
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor blinks on then turns off after computer boots up
It could be your LCD backlight giving you problems. When the image "goes off" shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 20, 2007 | Hyundai L72S-8 17" LCD Monitor
Fading monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps, Good luck.
May 29, 2007 | Proview PL 766s 17 in. Flat Panel LCD...
My monitor not stay on
Very common for this model that top backlight globe goes faulty. Can be also inverter PCB fault. If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
Mar 28, 2006 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Computers & Internet Logo
784 people viewed this question
David Payne
David Payne
