Question about Microsoft Windows XP Home Edition
Programs running in background on my pc
I belive I have too many programs running in my background and Ithink its slowing my machine down...how do I find out what should & should not be running???? HELP!!!!
  • 3 Answers
The trick is to choose which programs run at startup. These background programs will slow your computer down. I use "startup optimizer", this free software will rank your startup programs, allow you to research the need for each, and turn on or off the program. It also lets you create a backup file, just incase you turn off too many options and screw up your computer.
I got it from downloads.com
Posted on Nov 18, 2008
    Novelist:
  • 100 Answers
There are several ways, but two of the easiest are to look in Start => Programs => Startup and take a look at your taskbar (lower right hand corner). The Startup folder lists programs that will run once you login to Windows. The Taskbar shows icons for most (if not all) of the programs running at the present time.
If you need a more detailed answer, let me know. Spybot S&D also have neat utility to help with programs that run automatically. However, you don't want to mess around with it, unless you know what you're doing.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
What are the reasons to system becomes slow? please give me right suggestions. i am unable to solve this problem. And is there any good tutorial videos for my problem please send the url link.
Systems usually slow down over time because the user installs programs that run constantly even when you aren't using them. If you look at the right side of the taskbar, you'll see icons for volume and probably an antivirus program that you need running - but often times there are other programs there that are slowing down your PC, such as updates you need to install or games. If that's the case, then changing the settings of those programs so they don't run in the background and closing them will free up more system memory and processing power, and your computer should run closer to the speed it was at when you first purchased it.
If you have any specific programs you find that you don't know how to disable, just let me know!
Aug 15, 2014 | Computers & Internet
Slow youcam
there is usually a lag depending on the connection. There will also be a slight lag locally depending on the speed of your processor
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 11, 2013 | Computers & Internet
Cursor freezes after start pg surfing
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid your PC from freezing & slowing down, The one well known and reliable program is Reginout to manage everything on your PC & will secure your OS from annoying freezing and lagging problems.
Dec 08, 2013 | Computers & Internet
Cursor frozen
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid your PC from freezing & slowing down, The one well known and reliable program is Reginout to manage everything on your PC.
Nov 18, 2013 | Dell Inspiron Computers & Internet
Hp compaq evo n1015v notebook running too slow?
Shut pc down, restart, run antivirus scan, run hard drive defrag and clean up, shut down unecessary programs running in the background. Good luck.
Sep 21, 2013 | Compaq Evo D510 Minitower (Open Box)...
Requirments working too slow
You may need to do some "housecleaning". You probably have to many running processes. There are many Freeware programs to use to clean up and disable all unnecessary programs. All programs that start with windows will slow down the Laptop. Most are unnecessary and should be Shut down until needed. Two freeware programs to help are , 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This will remove the junk, use cleaner and registry, configure, scan, delete. In the TOOLS section , select STARTUP, disable ALL unnecessary Startup programs to speed up starts and running, the more that's running in background the slower your machine will be. Your specs are minimal at best, you need to "lighten the load" on the processor and the memory. Uninstall ALL unnecessary programs, junkware, toolbars, extensions, etc. on your web browsers. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ This freeware programs will remove any malware, and other nasties. In the install, UNCHECK the Trial Pro version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Here are more tips to speed up Windows 7: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Usually the machine slows due to the owner's input and the owner can speed it up doing some routine maintenance.
May 17, 2013 | eMachines Computers & Internet
Internet barely works
Step 1:
Most of the programs running in the background of your computer start automatically during PC reboot. These applications were added to the Windows startup menu during default installation. However, you probably do not need all of the programs that are currently running on your computer all the time. This only slows down your PC and the reboot time. Fortunately, you can access the Windows startup menu and remove the programs you do not need to have running automatically. Turning off the programs shuts them down until you enable them again through the "Start" menu.
Go to the "Start" menu, type "msconfig" in the "Start Search" box and press "Enter" to start the System Configuration utility. Click the "Startup" tab in the System Configuration window. Uncheck the programs that you want to turn off and stop from running in the background. Click "Apply" and "OK" to save the new settings. Restart your computer.
Feb 24, 2013 | Dell Studio Computers & Internet
Too slow
A bit vague. I would guess you have to many running programs. Use these two freeware programs 1, CCLEANER at: http://www.filehippo.com/download_ccleaner/, This will clean the junk from your machine. In the TOOLS section, STARTUP, Disable ALL unnessary Startup programs. Remove ALL TOOLBARS they all killers on broswer speed. 2, MALWAREBYTES at :http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK, the PRO TRIAL version, you want the freeware version. Run A FULL SCAN, DELETE ALL RESULTS, REBOOT. REMEMBER, Every program that "runs at windows start"and runs in background needlessly, slows down your machine, over time they add up. When you install a program look for the "start at windows startup" and UNCHECK. For further assistance respond to this post.
Jan 04, 2013 | LG X130 Netbook
My dell is runing slow
The most common causes of a slow PC is:
a)It has been infected with viruses and/or spyware
b)You have too many programs or apps installed on your PC which are running in the background and slowing the tasks you are busy with.
Install a good anti-virus program such as AVG free edition. You can download it for free from www.avg.com
Once downloaded run a full scan to detect viruses and spyware which may be slowing your PC down.
Also uninstall any programs which you are not using.
Best wishes,
Graemevm
Jan 14, 2012 | Computers & Internet
Vary slow starting up
Computers are often slowed down on boot because of programs that are starting and running in the background.
To shut prevent these unneeded programs from starting go to: start> run> type: msconfig press enter Select the startup tab and uncheck programs that you do not use. Make sure you do not uncheck any antivirus programs or operating system utilities (you can tell the the manufacturer that is listed and their location, if it has a location such as the windows folder don't uncheck it).
After selecting apply you will be asked if you want to restart your computer, select yes. Upon startup you will be told that you made some modifications. Check the box to never inform you again and click ok.
Jan 06, 2010 | E-Machines eMachines Desktop PC
Microsoft Windows XP Home Edition Logo
265 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
