Question about Euro-Pro F1066 Deep Fryer
I want to change the filter
I want to know where to buy the filter a metel net inside the lid
  • wkailey Jan 10, 2009
    I am reallly mad at this company! They also sold me a useless Shark cannister vacuum that has no rotoray brush in the head. Yes, I was a ****** to buy it. It picks up nothing, and I mean NOTHING. As for this french frier, no other consumer frier has enough wattage and capacity to make french fries for a family of 4 in 1 to 2 batches. Great product! I was looking for something like this for years when they finally introduced it. Then, a year later, I find out you can't buy filters for the darn thing. Infuriating. I am boycotting Eruo-pro from now on. Suggest others do the same.
  • wkailey May 11, 2010
    Good idea, but I already tried that, and there doesn't appear to be anything on the market : (
I tried all over the internet looking for filters, even contacted Sears where I bought the fryer.  All anyone wants to do is sell you another fryer - a bit extreme when all you want is a replacement filter.  In the end, I got a bit creative & solved the problem myself for under $1!
Go to your local supermarket & buy a pack of the thin 'Scotchbrite' nylon pan scrubbers.  Strip the fryer lid apart - 5 screws, cut scrubber pad to size & reassemble.  The scrubber pad is slightly thicker than the original foil filter, but the lid will reassemble.
Happy frying.............
Posted on Mar 07, 2009
  • 979 Answers
You may can google "filters for deep fryer" and possibly find it there.
Posted on Feb 17, 2009
How do i xchange dust filter
switch off projector
turn the projector upside down, u will find a netted plastic which has a sponge filter inside
if the sponge is damaged put a new sponge filter and fix the netted filter to hear a lock sound.
switch on the projector and clear filter hours in the menu
you are done
Jan 17, 2013 | Hitachi Performa CP-RS55 Multimedia...
Was driving and went to park now i have no reverse,but have all the other gears
sounds to me like it is long over due for service. if the ****** can be saved at this point it needs a fluid and filter change pronto.... have you by chance made sure there is fluid still in the ******? and if there is still fluid in it you should smell it and see if it smells burnt run your fingers down the dip stick and check for any metel shavings in the fluid. with luck no burnt smell and no metel shavings and fluid still in the transmission with a service and filter change you could be backing up again in no time. but if you smell burnt fluid or see shinny metel flakes of feel corse metel shavings in the fluid i am afraid you are in for an expensive adventure and will be replacing either the car or transmission sorry for the bad news
Jul 15, 2012 | 1997 Honda Odyssey
I have a large spa and am not sure how to remove the filter as there is no manual with the spa.
I would first need to know where the filter is located in the spa. Not knowing however, let me tell you how to remove it with a couple of different ways.
if the filter is inside a skimmer opening, you will need to make sure the pump is turned off and the filter will simply pull up. there may be a hair/lint basket inside that type of skimmer that much be removed first. those are normally put in there with a twisting type action. there will be two flat sides to the basket that when lined up with the adjacent flat spots inside the housing the basket will come right out and under that is the filter.
The other style of filter is a pressure filter. This style has a lid with a ring-lock that holds a lid down. Once the ring-lock is unthreaded you can pull the lid up and get access to the filter which is just pressed down into the water.
Jan 07, 2011 | Home
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Jul 17, 2010 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Broken toilet lid
Sophie; What you can do is chk with Lowes or homedepot. I did the same thing more than once and ended up buying the whole tank. Try to order it and bring the part no. with yo. Try to get the phone no. of the manufacturer, They may ship you one or do a search on the net by typing in the mfg and part no. Good Luck.
Nov 17, 2009 | Water Heaters
Fault 715 shift solenoid for a 1999 s10
The shift solenoid is what changes the gears in a gm auto tranny. To change it you just need to drop the tranny pan and remove the filter. You'll see a plug with to wires attached to a plastic and metel piece. Remove the plug and the soleniod just pulls out. If you order the part first(about $25) you'll be able to recognize the old one when you drop the pan. You may as well just buy a filter kit while you at it(about $20). It comes with the filter and a new pan gasket which you will need anyway.
Nov 06, 2009 | 1999 Chevrolet S-10 Pickup
Changing the air cleaner filter; don't know how to put the new on
Open up latches on air cleaner box. Notice how filter is set inside. Replace filter, close lid and latches.
Sep 16, 2009 | 2007 Toyota Camry
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
1998 audi a6 air filter change
If it's the 2.8L V6, the air filter is in the big plastic box on the passenger side of the engine bay, between the back of the headlight and the secondary firewall that walls off the engine compartment from the battery compartment. Just undo the clips holding the lid onto the box, lift the lid, and you'll see the filter inside.
Jun 22, 2008 | 1998 Audi A6
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Euro-Pro F1066 Deep Fryer Logo
628 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
