Question about Canon CanoScan 4200F Flatbed Scanner
Code 2,250,0 ''Error in scanner. use installation manual''
Photoshop no longer was able to acquire images so I used the Canon Toolbox until today when I inadvertently invoked PhotoShop. Now I only receive the above message.
I think that I should locate the driver and delete it. Hopefully find either the original disk or an online file available.
Any help gratefully received.
2 Suggested Answers
  • 1148 Answers
SOURCE: MacOSX 10.6 No "Twain Acquire" in Photoshop.
canon website download new drivers and apps
Posted on Nov 03, 2010
Your scanner model is not supported on windows 7.
Jun 07, 2011 | Canon CanoScan N1240U Flatbed Scanner
I download XP driver for N1240U from Canon. Everything seems to work including successful diagnostics check. But, when I try to scan using Toolbox, I get a TWAIN error message. My file system is NTFS....
scan with adob photoshop /import - from - your scaner device/ , it will be correctly, maybe toolbox not working normally, if with photoshop will not be resaults, in control panel \ in scaner and imaging devices see is there your scanner, if it will not be in there, reinstall driver.
Jun 01, 2011 | Canon CanoScan N1240U Flatbed Scanner
I lost my canoscan lide 20 installation cd
From this official link you can choose your operating system (windows XP, Vista, Windows 7), your language and download the latest version of drivers/toolbox for your scanner.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer, including your operating system and prefered language.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Mar 16, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I don't know how to get my MP210 to scan! And pressing the button do nothing! I am using a MAC too.
Issue: Scanning from MP Navigator cannot be performed in Mac OS X 10.5
Solution: Use a Different Application such as ImageCapture or PhotoStudio to Acquire images
Some incompatibilities have been noted with some versions of Toolbox and MP Navigator.
Use a Different Application such as ImageCapture or PhotoStudio to Acquire images. ImageCapture and ArcSoft PhotoStudio (if installed) can be found in the Applications folder on the hard drive.
Check the Canon Website frequently for updates to Toolbox or MP Navigator
May 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox,
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Installing CanoScan Lide 20 / Lide 30 into Mac OS X 10.5.5
I found this scanner at a garage sale today, and had trouble finding this info myself. Finally stumbled upon this site ( )
I'm using it on a Powermac G5 but both the driver and toolbox app say they are univeral binary. Hopefully this gets you up and running too:
CanoScan LiDE 30 on Mac OS X 10.5
This technical help may seem completely out of place on this art blog but after scouring the internet for 3 hours trying to set my 6 year old scanner up on my new MacBook, I found this info half way down a lengthy comments section of a random blog. So I thought I'd post it here (slightly altered) as a message in a bottle to anyone else in need of it.
How to set up CanoScan LiDE 30 on Mac OSX 10.5
Select MAC OS X
Download BOTH:
LiDE 20/LiDE 30 Scanner Driver Ver.
(Mac OS X)
CanoScan Toolbox Ver.
(Mac OS X)
INSTALL CanoScan Toolbox Ver.
INSTALL LiDE 30 Scanner Driver Ver. . Make sure Applications>CanoScan Toolbox 4.1>Plug-Ins is selected as the install location.
You will be asked to RESTART. You should.
When you run CanoScan you can choose Photoshop as the default program to open the image in once it has scanned. You do not need Photoshop to open using Rosetta for this to work.
NOTE: If you want to scan directly from within Photoshop CS3, you need to copy the driver 'ScanGear CS 7.0X' which is found in Applications>CanoScan Toolbox 4.1>Plug-Ins into the photoshop pluggins folder, Applications> Adobe Photoshop CS3>Plug-Ins>Import/Export. You also need to open photoshop in Rosetta mode. Apple + I on the photoshop icon and select 'Open using Rosetta'. I would not recommend using this method though.
Go to System Preferences>Accounts>Login Items and remove both of the following:
Feb 15, 2009 | Canon CanoScan LiDE 50 Refurbished Scanner
Calibration cannot be performed Error
I had the same problem when upgrading to mac os x. I was trying to scan directly from Photoshop but got the calibration message. I tried the two solutions given at the Canon website but they didn't work. I ended up downloading the Toolbox application to scan directly from there but the same message appeared. After installing the Toolbox application I unistalled the driver (11250) and reinstalled it. I opened Photoshop and tried scanning and the calibration window appeared only this time it didn't stop to give me the "Flim Adapter" warning. I must point that the scanner lid was open when this happend but I'm not sure that had anything to do with it.
So apparently it works if you have the Toolbox installed prior to installing the driver. The driver, Toolbox application and unistall driver can be found at Canon's website. Hope this helps.
Aug 30, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
683 people viewed this question
old marine
old marine
