Question about Asko D1796FI Built-in Dishwasher
ASKO D 1796 NEEDS COMPUTER BOARD
Hi, My Asko Dishwasher D1796 needs a computer board, it is 8 years old & not under recall. Is there a place I can get a board that is possibly used but works? Sometimes I know people get rid of perfectly good dishwasher's when they remodel so was wondering if there is one out there. Otherwise I have to get a D3251FI brand new unless there are any of those out there on sale???
Thank you
    Top Expert:
  • Asko Master
  • 52,509 Answers
FIXYA does not know of any used appliance retailers . check with a local repair shop .
Posted on Oct 02, 2017
Rotu
  • 175 Answers
SOURCE: Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Posted on Jan 13, 2007
  • 641 Answers
SOURCE: Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Posted on Aug 27, 2007
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
Krazytech
  • 725 Answers
SOURCE: my Asko D1976 dishwasher is not cleaning well, and
I would check you drain it must be clear and it must also raise above the bottom of the sink to keep water from the sink going back into the dishwasher..
Hope it helps if Not let me know more about you problem..I can help
Posted on Sep 26, 2009
Asko D1796 control panel will not reset....it is showing 5 on it
shut power off at breaker, look under washer there is a pan, if any water is in that pan, there is your problem, remove the water with a towel, plug washer back in
Oct 31, 2010 | Asko D1796FI Built-in Dishwasher
My Asko D1976 dishwasher is not cleaning well, and
Sep 08, 2009 | Asko D1796FI Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Jan 01, 2007 | Asko D1796FI Built-in Dishwasher
Dishwasher overfilling
I have been working on ASKO for several years and have never seen one fill and drain at the same time. Usually if it drains and cannot be stopped, it is because there is water in the lower tray that needs to be removed or left to evaporate, and then it needs to be figured out why the water was there in the first place. If you could post back with more info (does it fill, sit for a while, then drain, or is it doing both at once) I would be glad to help. Good Luck!
Oct 18, 2006 | Asko D1776 Built-in Dishwasher
Asko D1796FI Built-in Dishwasher Logo
121 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
