Question about ViewSonic G810 21" CRT Monitor
Screen flickers After turning on the monitor, the screen flickers/twitches and sometimes it seems to shrink and expands just a little bit. Is this monitor on the verge of going out or do I need to check the card or drivers? Is it worth repairing this monitor? Thanks.
  • 56 Answers
The problem is that it is on the verge of going out my mother had a monitor go out and it did the same thing. Also if you have any high frequeny things around your monitor thatr also migh be the thing. Try a magnet or demagnitze the screen if you have one on it.
Posted on Dec 04, 2006
SOURCE:
T61 Screen flicker and distortion.
Sometimes if the machine overheats it can weaken the solder points on a video chip so that if you touch it or bend a bit it straightens out and works fine. You can get that repaired board can be re-soldered by a company that does that sort of thing. For around $40-$80 dollars you have to ship the board and have it done. Usually pretty fast service. or it seems that maybe you may get lucky here cable monitor could be slightly wire pinched. You will need to take Monitor and cover plate off the front of the keyboard where the power button is located and check the connection it may also just need a good cleaning or make sure it is not pinching anywhere and is straight forward. This happens sometimes with monitors for laptops the moving monitor back and forth over time can cause wear on the wiring.
I would check that first wiring then clean the connection with rubbing alcohol the kind that drys out. While you at it I would also dust it out good especially the copper tube vent ports make sure they are free of debris. If this does not solve the problem also check the lamp. Hopefully it is not the screen going bad itself. It does seem to me to be the monitor cable pinching on you or shorting check that out good. Or have a pro shop do it for you.
I hope that assisted you? John
Apr 20, 2012 | Lenovo ThinkPad T61 Notebook
Grey, flickering screen
Possible LCD issue, but you have to check first in BIOS if the same symptoms.
If in BIOS doing the same it is already a mechanical failure.
If not? check all the connections and also try reformating the system.
May 19, 2010 | HP Compaq Presario CQ50-210US Notebook
Latitude d820 screen twitch
Take it to a service shop and ask them to open the unit and the display. The cable connector to the display is loose on one side.
Jun 22, 2009 | Dell Latitude D820 Notebook
My problem with this screen is that when I try to go to another web site the whole screen starts flickering and I can't go to another web site. Happens once in awhile, sometimes it works great and then all...
Could be a loose cable inside off the monitor. There is a cable that hooks into the back of the lcd and if that is even loose by a little bit it can make the screen act crazy. If you can get the back cover off of the monitor, try to unseat and reseat that cable to see if the problem goes away.
If you do that and it still exists then the lcd is bad and the whole monitor needs to be replaced.
May 02, 2009 | Acer V193w LCD Monitor
Screen blinks - sometimes shrinks & disappears and then re-appears
just do this, resolder the whole circuit board and crt board.
Mar 12, 2008 | Computers & Internet
173v flat lcd black screen
I've had a similar problem with my 173v monitor since I bought it a few years ago. When I start my computer, Mac or PC (I've connected it to both), the screen remains black and the green power light flickers once a second, almost like it's twitching - it's different from the blink it makes when the computer isn't turned on but the monitor is. Like kronem, I have to unplug the line from the monitor to the computer, wait for the monitor to register no input, and then plug the monitor in again before it displays anything. I've never figured out a way around the problem - I hate it!
Feb 21, 2008 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Oct 27, 2006 | RCA F35731MB 35" TV
Convergence & Pincushion Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Aug 31, 2006 | Philips Magnavox 9P6034C 60" Rear...
ViewSonic G810 21" CRT Monitor Logo
202 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
